No Headlights!
Old Aug 19, 2007
V-mac's Avatar
V-mac is an unknown quantity at this point
Question No Headlights!
So when I started my car up this evening ('02 Civic LX, MT, 140,000+ km) my DRL light is on (after releasing e-brake, but without lights turned on), the SRS light is on, and the Battery light is flickering intermittently.
When I turn the light switch on, the DRL indicator goes out, but I only get the marker lights on... no low or high beams at all.
After 30-40 mins of driving, the battery light stopped blinking for the most part.
After about 1.5 hrs driving, stopping and re-starting the car, no more SRS light, but still no headlights.
2 DRL fuses under the dash and 2 headlight fuses under the hood are all fine.
I also removed, re-sanded, and re-attached the ground wires behind the passenger headlight because I have them re-located due to my CAI mount.
Anyone have any ideas?
Old Aug 27, 2007
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
Re: No Headlights!
i could be do to the recall honda has put out. the wirring that was used on the head lights was to small and would melt down cuzing the headlights not to work. check with you nearnest honda dealer if you havent gotten this problem fixed. this may be your problem.
jay
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
