Civic wheel bounce
Old Apr 26, 2023
Kevo1984's Avatar
Kevo1984 is an unknown quantity at this point
Civic wheel bounce
Hey everyone I have a 2016 civic lx.
everytime I try and do a burn out the tires just bounce like crazy and don’t get the smoke lol
what can I do to stop the tire bounce ?!!
Old Apr 26, 2023
Colin42's Avatar
Re: Civic wheel bounce
A: Don't do burnouts
B: Eliminate the wheel hop
Old Apr 26, 2023
Kevo1984's Avatar
great gives me some amazing advice!!
Old Apr 26, 2023
what the point of doing burnouts?
shocks might be dead after doing it
Old Apr 26, 2023
Kevo1984's Avatar
because I can ? Because I want to not sure why the burnout thing is a big deal it’s not like I’m the only one doing it.
Old Apr 26, 2023
read the 2nd sentence too
just because others do, I would not... waste of tires and wear on suspension, mounts, more money later
it will only show off the engine, not your skills, so nothing to bloat about.
put some cheap tires with low grip instead if you insist in doing it. Also, lift car and inspect for worn bushings, engine/trans mounts. And the shocks
Old Apr 26, 2023
you are more likely to impress people by doing a three wheel cornering throughout the whole corner - civics are better at that, cornering.
and requires skill. Not only a bought engine
better for suspension wear than just burn-outs and requires high grip tires instead of low grip tires (which are also dangerous in streets)
PS: read about autocross, SCCA, don't do this on the streets
many FWD cars does this if properly setup
RWD cars will lift front tire, though
Old Apr 27, 2023
BrotatoChip's Avatar
Super Moderator
In general, stiffer engine mounts, stiffer suspension, and a traction bar (if applicable) are the best options to get rid of wheel hop.
Old Apr 27, 2023
Kevo1984's Avatar
thanks very much for your reply.
any recommendations on any of those? Brand wise ?
Old Apr 28, 2023
Super Moderator
Unfortunately not. I don't own a 10th gen and I've never had issues with wheel hop.
sr89
Apr 23, 2011 02:46 AM
nickm748
Jul 8, 2004 02:34 PM
IronFist
Dec 23, 2003 07:01 PM
deezshady
Jun 26, 2003 12:09 AM
Silversleeper
Apr 15, 2002 11:39 AM
