Is this indicative of a sticky tire or what?
Old Dec 22, 2003
IronFist's Avatar
Alright, you know how if you turn and let go of the wheel and then accelerate the wheel will re-center itself? Well if I take a turn hard and acclerate sometimes the wheel gets like "stuck" in that position and doesn't re-center itself (not that I take my hands off the wheel, I'm just saying for example). Does that mean I have sticky tires or something or does that mean something is wrong or what? I have Falken Ze-512 205/60/15
Thanks.
Old Dec 22, 2003
HondaLuver's Avatar
Its a celebration bitches!
somethings wrong... i really doubt its ur tires...
Old Dec 22, 2003
Zzyzx's Avatar
Autocross Junky
yup, something is wrong..... have you hit any big potholes lately? you may have bent the steering rack.. or knocked the caster off. Get that checked out.
Old Dec 22, 2003
RiceBuRNeR's Avatar
Turbo Member
It sounds like the tire is losing traction, not having too much.
Old Dec 22, 2003
666's Avatar
666
666 is an unknown quantity at this point
Its probably just torque steer, usually happens when you accelerate in a straight line too, it pulls the steering wheel to one side. When you have the wheel turned it probably has a more dramatic effect on it.
Old Dec 22, 2003
IronFist's Avatar
It doesn't lose traction when this happens, so it's not like I'm sliding and that's why the wheel isn't turning back. The tire has grip the whole time.
Old Dec 23, 2003
RiceBuRNeR's Avatar
Turbo Member
dunno then, I know that If I loose grip in a corner that the wheel is kinda hard to straighten, but if you still have traction then Im not shure whats happening.
Old Dec 23, 2003
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
yeah my car did that when i first installed my coilovers (full), my whole suspension was messed up, then i got everything retightened and aligned, then it fixed that issue.. it was annoying as hell too..
Old Dec 23, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
yeh and ur tires are Z rated not very sticky have u had an alignment lately?
Old Dec 23, 2003
Zzyzx's Avatar
Autocross Junky
the speed rating has no bearing as to how sticky a tire is..... it just tells you how fast you can safely go with them and not have them tear them selfs apart...
Old Dec 23, 2003
the tires he has are the same as the ones im riding on hard as hell not sticky at all
Old Dec 23, 2003
IronFist's Avatar
My tires are H rated, not Z rated.
SimpleUser
Apr 24, 2021 02:54 AM
alaga
25
Aug 13, 2015 04:42 PM
jedi
Aug 3, 2015 04:26 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
ezone
HIDs and Retrofitting
Jul 4, 2015 12:44 PM
