Electrical Post your Electrical issues here!
Battery drains in 3 days while off
Old Sep 4, 2024
DES1987's Avatar
DES1987 is an unknown quantity at this point
Hi everyone,
​​​​​​I was hoping I could get some help troubleshooting an issue with my 2018 civic EX-T sedan. I recently got a remote work position and now that I'm not driving every day, I've noticed my battery dies in about 3 days (without any driving).
Initially I thought I left a light on, and so when I tried charging the battery it says bad battery. I went and got a new battery, started right up but no lights were on. I also saw the alternator was charging the battery but when I turned the car off it was draining pretty quickly. Within 3 days it was very low, so I turned the car on for half an hour and it charged the battery.
I have a multimeter, but no idea where to start. Any ideas on what I can check, and in what order? Or is there any additional info I can provide? I have LoJack, but I think that's the only modification on the car. Also I had a tail light out before I stopped driving daily, but I moved the wires around behind the tail light box a little and they started working, so I left it alone and put the tail light assembly back. It still works normal, but maybe this broken wire needs to be replaced? I've also read about checking fuses and relays, but I haven't done that yet.
Any help would be greatly appreciated, thank you!
Old Sep 4, 2024
DES1987's Avatar
Re: Battery drains in 3 days while off
Update: I saw a video on YouTube explaining how to diagnose parasitic draw, and so I disconnected the ground and measured from the post to the ground and got .6 amps. So the video said to clamp the multimeter to the post and cable to get a constant reading, and pull fuses until it falls below 50 milliamp. I am going to try this in a little bit to narrow down the component(s) that is(are) causing the drain.
Old Sep 4, 2024
DES1987's Avatar
Update 2: what should I do next? I pulled a 10amp fuse that looks like it's a backup light or camera, probably the light, and my multimeter went dropped significantly, .7a to .054a... See top right hole, there was a 10a fuse there. And then corresponding diagram below.
Old Sep 5, 2024
BrotatoChip's Avatar
Super Moderator
Here is everything on fuse A18.
Devans
Electrical
Sep 24, 2023 05:47 PM
antney4
Apr 2, 2013 05:40 AM
antney4
Electrical
Feb 26, 2013 10:20 PM
popee
Nov 2, 2007 11:49 PM
Gflow
Oct 4, 2007 02:10 PM
