02 civic battery/electrical issue
Old Feb 26, 2013
antney4's Avatar
antney4 is an unknown quantity at this point
Ok my battery light would come on if it rained a lot been doing it since I bought the car but now problems always went out. Two weeks ago I was driving to work and battery light was still on from the day before I didn't think anything of it. On my way to work lights dim then radio shut off then gauges stopped working. I pulled over I got the car jumped to try TO make it to the auto parts store. after the jump battery light went off so I went to the store and had the battery and alt. Tested both were good but my neg. Terminal was lose. So I thought that was the problem. No problems after that until yesterday can out and started car and battery light was on (no rain). I didn't want to take a chance so I got a new battery after work and tried that. Battery light didn't go out and after it running for a short time battery was low. Any help would be greatly appreciated I don't know where to start.
Old Feb 26, 2013
Re: 02 civic battery/electrical issue
Do you get a loud SCREECH noise sometimes when you start it?
See if the belt is too loose.
Old Feb 26, 2013
fusion158's Avatar
fusion158 is an unknown quantity at this point
I had a problem like that a few months ago (minus the rain) with the battery draining etc. For me it turned out to be a relay that was sticking in the on position. I suggest getting a multimeter, turning off the car, doors closed etc, disconnecting the positive terminal and putting the meter between the positive terminal on the battery and the positive cable and see of there is any current draw. If you're getting anything excessive then something is either stuck on or there is a short.
Old Feb 26, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Check the voltage at the battery with when the car is on with no load with a multimeter. See if the alternator is actually charging it. It should be somewhere around 14 volts.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
McD
Apr 29, 2015 03:50 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
civic_gt
Apr 19, 2015 08:15 AM
skywalker
Nov 8, 2001 05:04 PM
