Electronics Post your questions about Electronics problems here!
Ghost in the machine?
Old Apr 23, 2023
TheOldMan's Avatar
TheOldMan is an unknown quantity at this point
I have a 2020 Civic EX 2-door coupe with only one RC key fob that is always in my possession. The fob is kept by itself with buttons turned outward in a small outside pocket of my cargo pants, and there are no other ambulatory people in my household. I keep the car locked and in a locked garage at night (it's set to automatically lock when I walk away, and I listen for the audible locking beep). I never leave the windows or sunroof open, and try to always set the parking brake when I leave the car. When I went into the garage for the first time on April 22, around noon, both windows were fully open, the sunroof was tilted up, and the parking brake was off. I might have forgotten to set the parking brake when I left the car on the 21st, but the windows and sunroof were definitely closed. Has anyone on the forum heard of an event like this in a Gen10 Civic coupe? Is there some kind of RC box out there that would allow a prankster to manipulate my car like this from the street?
Old Apr 23, 2023
Colin42's Avatar
Re: Ghost in the machine?
A nutton probably got depressed. If you hold down one of the buttons it will roll down the windows, and i guess vent the sunroof. Never owned a honda newer than 05, so I can't comment specifics, but I know you can do this with the newer models.
Old Apr 23, 2023
TheOldMan's Avatar
Your speculation is not likely, because the buttons are all recessed below the rigid face of the fob, and my fob is carried in a separate outside pocket, with the buttons facing outward. Also, I could not find any mention of this feature in my owner's manual or the dashboard Vehicle Settings menu. If someone in this forum can tell me where to find "one-touch fully opens both windows and tilts the sunroof up" instructions (if they exist for my car), or offers another plausible explanation, I can try to duplicate the event.
Old Apr 23, 2023
did you sleep with the keys in your pocket?
Old Apr 24, 2023
TheOldMan's Avatar
I almost didn't reply to this post, but then I noticed you were a forum administrator, and figured it was intended to be humor. So your question conjurs two scenarios. One is that you're asking if I fell asleep on the couch during an episode of Yellowstone and somehow wound up facing the opposite direction in a seated position while pressing on my key fob buttons. The answer to that is no. The other is that you're asking if I got likkerd up and passed out in bed with my clothes on, then somehow pressed the magic combination of buttons on the key fob while unconscious; or maybe you're asking if I normally sleep with my clothes on and keyfob in my pocket for a quick getaway, in case the Sheriff shows up with a warrant. The answer to both of those is still no, and by the way, no one has yet come up with said magic button combination that I can test.
Old Apr 24, 2023
BrotatoChip's Avatar
Super Moderator
You press the unlock button twice, holding it the second time. Sunroof and windows should open. It's not some complicated code you have to input. Something that could happen with the key in your pocket.
Old Apr 24, 2023
honestly, I was asking a serious question...
butt calling is common with phones, remote button pressing in pocket is also common...
Old Apr 24, 2023
Colin42's Avatar
See?
I've started my truck by accident a couple of times.
Old Apr 25, 2023
TheOldMan's Avatar
Yoiks, it woiks! Thanks for solving the mystery. Is this in the owner's manual somewhere , or is it like a secret handshake that the salesman would have told me about if I had bought the car new from a Honda dealer? Regarding keys or coins setting them off, there is no way the the fob buttons could contact either, BUT I remembered today that I was moving some heavy boxes around the house the night before, and the corners could have easily made contact. Great, so now I have another pain-in-the-*** modern convenience to watch out for. Here are two inconveniences I discovered about this gimmick (unless BropotatoChip has another magic trick he'd like to disclose):
1. If you release the second button push before the windows & sunroof are fully open, they stop opening, and you can't complete or reverse the process with the fob.
2. Once you have completed the process (either fully or partly), you cannot reset anything you opened from the fob. You have to at least put the car in accessory mode, then manually close the openings with the interior controls.
Old Apr 25, 2023
TheOldMan's Avatar
I understand; I was just having some fun, but there really isn't any way my keys or coins could contact the fob buttons. The small fob pocket is outside of my keys/coins pocket (you know, cargo pants), but the pocket is small enough that the fob cannot move around, and I always insert it with the buttons facing outward (due to a previous incident involving a collision between a moving segmented garage door and an inadvertently activated CR-V liftgate). As I mentioned in my reply to BropotatoChip, though, the buttons are susceptible to outside contact.
Old Apr 25, 2023
TheOldMan's Avatar
See?
Augh! That would not be pretty in my enclosed garage all night. Automatic start was the first modern convenience I disabled from the Home screen display when I took possession of the car, although it would have been handy when I was selling at retirement land dinners in Iowa, the winter of 1972. After each dinner, the locals would all start their cars and leave the heaters running while they went back inside and had a drink, and I learned that from them. Nobody ever had a car stolen. Nowadays, on California's central coast, I can't imagine the trouble that feature would get me into. Remember, I can't even be trusted with the remote for a CR-V liftgate!
Old Apr 25, 2023
no problems, I usually only joke when the issue is solved, or while trying to give a potential solution, but this was not the case...
Old Apr 25, 2023
Super Moderator
Google is a magical place
https://www.rensselaerhonda.net/post...-on-your-honda
Old Apr 25, 2023
TheOldMan's Avatar
Message received, 5X5.
...Oops! I spoke too soon. Thanks for the link to instructions for turning off remote window open, but Rensselaer apparently intends them for newer models, because my dash display has no selection for Remote Window Control, even when scrolled completely down. I'll check with the local Honda dealer, but now I'm wondering if Honda slipped this feature into 2020 models in advance of formally offering it, or maybe they added the disabling feature to later models in response to complaints. Not quite as bad as gullwing doors that didn't open on DeLoreans (with people inside), but I still hope to find the formula to disable this "convenience."
Old Apr 25, 2023
TheOldMan's Avatar
...Oops! I spoke too soon....
Whoa! The Internet is a dangerous thing... check out the TorqueNews article on this exact subject: https://www.torquenews.com/1574/10th...e-goings-night. The article offers no revelations, but the two pages of comments afterward give me hope that I'm not crazy, after all (unless, of course, they and I are all asylum candidates).
Old Apr 25, 2023
Super Moderator
I cannot find any info on disabling the feature in the 2020 or older models.
Old Apr 25, 2023
woah, thanks for info
Old Apr 25, 2023
from surfing the google,
- Chrysler cases were linked to a piece inside the fob that came loose and was pressing the unlock button
- some BMW have some anecdotal cases with door wiring? Some a chassis control module or reprogramming
No real solution for multiple Honda models
same for Mini's
several reports that the fob was on a table or hanging and still it opened.
Old Apr 26, 2023
Super Moderator
You could call up a dealership and ask if the feature can be disabled.
Old Apr 26, 2023
Colin42's Avatar
Agreed, dealer might be able to do something
Old Apr 26, 2023
TheOldMan's Avatar
I agree, and started the process yesterday, but it's not that simple at my local dealership. If I call, I have to leave a message and wait for a return call. If I send an email, it takes several days to receive any response. When I made contact with a Service Representative on the CR-V liftgate random opening, they responded: "We've never heard of that," and "If we can't duplicate it, we can't diagnose it." In my e-mail about the Civic fob yesterday, I included a link to the TorqueNews article. Depending on the local's response, I may be sending the same email to every Honda dealer in my region. I'll report the results back to this thread, if that happens.
Old Apr 26, 2023
one of the google results had someone reporting that he was lucky and it happened when the dealer had the car in their lot...
Now, the dealer only sells for Honda, Honda does not own the dealers. Not sure if dealers have a network for them to connect between themselves. If so, they depend on Honda to provide information.
Again, this is internet information (although the number of cases in each searched link is... high. And not only Honda
semora
Transmission
28
May 13, 2022 05:38 PM
stonedrives
Electrical
Jul 6, 2021 07:16 PM
thetexan
Brakes
May 2, 2017 08:13 AM
iveygatecivic
Oct 3, 2010 11:16 PM
SOHCboy83
Jul 23, 2002 04:41 PM
