stuck in park [solved]
last night i drove down the street to get some reception, turn off my car and sit there for a while talking. about 2 hours later, i try to leave and no dice. My car turns on just fine and the stearing wheel isn't locked or anything, but I cant take it out of park. anyone know what the hell is wrong and/or how i fix it?
I drive a 2003 EX (Coupe) if that matters at all.
On older Civics, there was a hole near the shifter where you could stick your key into it and release it. Unsure if it is still in the newer cars. See if you can remove a small cover near the shifter. Stick the key in to release.
Hope this helps.
Hope this helps.
so apparenltly the brake lights aren't coming on when i press on the brake pedal; i didn't see anywhere i could stick my key to unlock anything; and there was a small clicking, but i don't know if that's normally there or not. i mean that it was so small that it might always be there any i never noticed before.
If you can squeeze the shift button, but cannot shift out of park, the parking pawl is jammed or can also mean your car is developing a problem with the shift interlock safety system. Both of these conditions can be temporarily remedied by the shiftlock release. It's a black cover located above the letter P on the shift console. Remove the cover and depress the hole with a key or screwdriver, move the shifter to N and start the car (assuming it isn't started yet), then move it to drive and you're done. To prevent the parking pawl from jamming, always use your parking brake before shifting into park. This takes the load off of the parking pawl and prevents it from jamming in the future. If it still jams, you'll have to start troubleshooting the electromechanical shift interlock system.
As a side note, people should always use the parking brake. It's called a parking brake for a reason... I don't know where the term emergency brake came from, but I think its used a lot more as a parking brake than in an emergency.... Ok. I'm done my rant now.
where the hell is the brake switch?
Originally Posted by CraigW
If you do not have brake lights ?? Start with the fuses #7 in under hood box 15 amp, then check the brake switch.
it's a little darker now and i can see the lights for myself (i just had some stranger let me know if they were working or not earlier) and they appear to be working. it's possible that it was so bright outside that he couldn't tell. i don't know if they work when i press the pedal, but they certainly do work when i lock the car. if they work when i lock the car does that mean that the fuse is fine?
The taillights flash when you lock/unlock.
Look in the back glass or even in the mirrors while stepping on the brake it will be easy to tell if they are coming on or not.
The click should be heard and felt near the shifter.
If not working check the fuse mentioned.
re: stuck in park [solved]
hello!
So about a week ago I started to have this issue with my 2005 honda civic Id like some help troubleshooting.
I tried replacing the #7 fuse. I thought that worked but after about an hour of driving I parked at hoe and low and behold it was stuck in park again.
I tested the brake switch and it must be in working order because when I disconnect it the brake lights stay on.
I bought a code reader and it says I should replace my fuel tank pressure sensor. Could this be what is causing the gear shift to lock repeatedly? or is it more likely a horn relay issue?
Almost forgot to mention that after that one hour of driving when I thought I had it fixed, I realized the horn wasn't working.
Any ideas or input is greatly appreciated. Getting tired of trouble shooting but just in case its a serious issue I dont want to drive it anywhere. (I dont need it for commuting to work and back so I have the luxury of taking my time to figure out what is wrong technically)
hello!
Re: stuck in park [solved]
So I cannot depress the button on the gearshift, which I thought disqualifies me from that point. But I also had the impression that this was kind of a band aid solution that would mainly just get the car to a mechanics shop. Whereas I want to fix the underlying issue. If I just ignore what caused all these malfunctions in the first place the problem would just get worse wouldn't it?
Schurch1990
Oct 13, 2016 09:31 AM
tolgaek
Dec 19, 2014 07:41 PM
s7khan
Transmission
Mar 6, 2013 10:27 PM
