Rats eating cables
Old Mar 1, 2021
JeanCeleste's Avatar
JeanCeleste is an unknown quantity at this point
Rats eating cables
I've had nothing but trouble with my 2016 Honda Civic. I've always bought Hondas, but something is seriously wrong with the 2016 model. I think Honda is using inferior materials. Aside from having to have the cheap tires replaced, my latest issue has been with the metal splash plate falling off. It is held on with weak plastic tabs. Luckily, my mechanic used iron bolts to secure it back on. However, right before that, rats got into the engine bay and ate the harness wires, which were made of soy, of all things. Really? Soy? It was not necessary to replace the whole harness (although the dealership insisted that was the only solution) and my trusty local mechanic repaired the damaged wires using a more stable material--not soy. I also have a steering issue that needs a recall, but Honda is weaseling out of that. My next car will be a Toyota or NIssan or something other than Honda, and I will check the tires as well as the materials used for splash plate connection and engine bay harness wires before buying it.
Old Mar 1, 2021
Re: Rats eating cables
The wires being chewed did not start with the 10th gen.
Splash shield is held by plastic ones in my 7th gen too.
Old Mar 2, 2021
Colin42's Avatar
Every manufacturer uses the soy wires now
Old Mar 2, 2021
FRSam's Avatar
Click Here
It’s a shame that you want to move on from Honda, but please, avoid Nissan like the plague. Toyota’s fine, they’re just boring
Old Mar 2, 2021
Really? Thanks for that info. You make a good case for buying an older car. Wish I'd kept my old Hondas.
Old Mar 2, 2021
OK. Good to know.
Old Mar 2, 2021
we see 2001+ also having same issues
Maybe some 2000's
Gus Oenning
Dec 16, 2021 01:20 PM
sratrainer
May 7, 2012 08:35 AM
greeen01civic4d
Jan 17, 2007 07:15 PM
Killer Kabob
Jun 6, 2003 02:15 PM
