Intake Problem
Old Sep 25, 2002
XxJDMCivicxX's Avatar
Intake Problem
I have a copy of an AEM cold air intake and it was pretty loud and sounded nice, my friend revved the engine under the hood (without stepping on the pedal) and I think he did something to it. It doesn't sounded the same and when I push the gas hard it doesn't even seem to be connected any ideas what he may have done?
Old Sep 25, 2002
MSoft's Avatar
MSoft is an unknown quantity at this point
You mean he adjusted your throttle cable?
Old Sep 26, 2002
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
Yeah, just make sure the throttle cable is properly routed -it goes 180 degrees in that groove in the disc thing on the throttle body before it loops back into the cable housing.
Old Sep 26, 2002
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
when he said... "my friend revved the engine under the hood (without stepping on the pedal) " he didn't mean he adjusted the throttle. He revved the engine without the pedal, you know...
Anyway... You did check the intake if it's still on properly right? Check the rubber links and see if there's a leak..
Old Sep 26, 2002
MSoft's Avatar
How do you rev the engine without using the pedal? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Sep 26, 2002
CUE2k1's Avatar
there's a little **** or hatever you call it that moves when the pedal gets de-pressed. If you open up your hood and have someone rev your car for you, you'll see it. It's located near the rear of the engine.
Old Sep 26, 2002
MSoft's Avatar
Sor desu neh...
Old Sep 26, 2002
CUE2k1's Avatar
Quote
[hr]Originally posted by: MSoft
Sor desu neh... [hr]
ummm..... OK!!
Allecr3
May 22, 2015 01:24 PM
oqjoi
May 9, 2015 10:31 PM
ORskier
May 7, 2015 04:54 PM
carid
Apr 30, 2015 07:00 AM
skywalker
Nov 8, 2001 05:04 PM
