Adjusting throttle cable
Old Mar 19, 2002
2K1SiCDN's Avatar
2K1SiCDN is an unknown quantity at this point
I saw this in the DIY section, has anyone done this yet? If so was it difficult?
Old Mar 19, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
i did it before but i have adjust it back..cause just eats too much gas..
Old Mar 19, 2002
sweetsi's Avatar
sweetsi is an unknown quantity at this point
why would you adjust it for?? is there more throttle?? if someone has the answer, please reply. thanks!!!
Old Mar 19, 2002
1028CiViC's Avatar
it just keeps the rpm higher..like u feel u have more power..but more gas.
Old Mar 20, 2002
2K1SiCDN's Avatar
On the DIY page it doesn't say that it supposed to rev higher, only that you get better response from the throttle because there isn't as much slack there, maybe you adjusted it too far.
Old Mar 20, 2002
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
It should rev higher if you adjust it because it practically seems like it's stepping on the pedal just a bit. I used to do that to my old cars because they'd rev too low and would stall. I say if you know how to drive, you won't need that added slack.
Old Mar 21, 2002
CiViCBoY's Avatar
CiViCBoY is an unknown quantity at this point
Do not adjust the throttle cable your civ'. It should already be at it's tightest position. I checked mine a while ago and it already is. If you adjust it more, you will get higher idling as they mentioned...why? Because your throttle is now slightly open fulltime. Picture it as if you have your foot pressed down on the gas pedal a bit 24/7.
Tyler93
Mar 20, 2016 09:03 PM
velozp
Dec 13, 2015 11:28 AM
IronFist
Sep 25, 2015 07:13 PM
2.0.0.2
Sep 14, 2015 06:38 PM
Bricoleur
Sep 9, 2015 12:30 PM
