POOR Gas Mileage 2007 Honda Fit Sport
Rep Power: 0 POOR Gas Mileage 2007 Honda Fit Sport
Hi guys! I'm new here and I purchased a 2007 Honda Fit Sport Last week. But I can't get more than 210 Miles with a full tank. I just did an oil change and even changed the spark plugs. And put Lucas into the tank.
I really don't understand why I'm not able to get a minimum of 30mpg when i'm supposed to have 31/38mpg :-(
Re: POOR Gas Mileage 2007 Honda Fit Sport
How are you tracking mileage?
Need to record how much fuel goes in, how far you travel, several times in order to get an accurate reading.
the 31/38, is that for a Fit SPORT or regular fit?
Googling I got 27/35
https://www.fueleconomy.gov/feg/noframes/22860.shtml
Furthermore, the city rating is based on moderate stops, such as traffic lights. Getting caught in ANY kind of stop and go traffic will brutally murder your mileage. Furthermore, the tank size is 10.8 Gallons. In my 2014 the tank is 13 gallons, however when the gas light comes on I can rarely get more than 10 or 11 gallons in there. So by the same logic, you are most likely only putting something like 8 or 9 gallons in when you fill up. This is about 23-26 mpg. Remember, any kind of drive through, stop and go traffic, or idling will drop your mpg very quickly.
Sounds like you have normal mileage to me.
Rep Power: 0 Re: POOR Gas Mileage 2007 Honda Fit Sport
Prelude Owner
Odd question to ask on a Civic forum.
Funny though since I just bought a Fit sport. Like Jordan said you need to track it properly instead of just going by total miles. The Fit has a small gas tank so you may only put 8-9 gallons in it. Last time I filled up i calculated 36.5 the car was telling me 37.3. That was mostley highway with some stop and go.
How much stop and go do you drive? Are you driving short trips?
I have a 26 minute, 13.9 miles to work everyday. That's weird though. Should I try driving really slow? By slow I mean accelerating really slow or should I use the manual drive instead?
Received 1,451 Likes
Rep Power: 339 Re: POOR Gas Mileage 2007 Honda Fit Sport
Don't matter the tank size. How many gallons did you put in there?!? You have not answered that crucial piece of info yet. Read reply before answering, after all it seem you cannot differentiate a Honda fit from a Honda civic, after all..
MPG = Miles driven divided by gallons used.
Miles per tank is not relevant in the equation.
Your trip sounds like a bunch of stop and go with high speeds in between.
It takes a lot of gas to accelerate from a stop and hit those speeds.
The car can get decent mileage if you can go a steady speed without stopping or slowing down.
If you could time the lights and traffic right so you don't have to slow down you'd gain some mileage.
Read this thread from like 2 days ago, check the replies and also click the link to the 9th gen forum at the end and read the replies he got there.
https://www.civicforums.com/forums/197-mechanical-problems-vehicle-issues-fix-forum/364508-very-low-mpg-new-2015-ex.html
One week, one fill up. You are freaking out for nothing... especially if you serviced car in that week...
Sorry its just that I assumed having a minimum of 31mpg would get me at least 250 miles on a full tank instead of 220. I'll try different driving patterns or roads to see if I can get anything close to 38mpg.
What sort of plugs did you install?
Still got the original plugs?
How many miles are on the car?
Tire pressure?
I have to really work hard to hit the city mileage number in my Civic in warm weather. In the winter it's impossible.
Tire pressure?
I am telling you the empty tank light is not that reliable. Record the gallons you put in then calculate.
I used the original plugs when I was changing the spark plugs.
Okay then. I'll be sure to write down tomorrow how many gallons go into the tank and what the mileage I end up with by the time the empty light turns on. If anything it really does sound accurate. I don't have a lot of stop lights on my route to work but to everyone else it may be enough to affect my mpg.
Be sure to join and post on the fit forums. I have no idea what engine and aerodynamic effects a fit have. This is a civic forum, different car... if you have not understood that yet... results could be different even with same engine.
When I get to a computer, your thread will be moved to the general section, for it is not a civic.
Actually, air filters being clogged has no effect on gas mileage. The only thing that is affected is peak horsepower.
(Look it up if you don't believe me!)
tylerginevan
04-27-2015 12:29 PM
