What Does Adjusting The Throttle Cable Do?
Old Jan 9, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
Ive seen alot of people saything they adjusted the throttle cable what does it do and how can i do it??
Old Jan 9, 2006
So I take it no one on right now knows?
Old Jan 9, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
DIY: Adjust Throttle Cable
Your questions make baby jesus cry.
search.com/org.gov.nu.r.teh.noob
Old Jan 9, 2006
sometimes when the cable gets too loose from normal usage, pressing the gas pedal to the floor won't be able to open the throttle body completely like it should. so you would never get full throttle hp. Tightening it makes sure it will open fully. it just removes slack in the cable.
Old Jan 10, 2006
CivicsRdBest's Avatar
the car will respond nanoseconds quicker! hehe...
it gets rid of that annoying little gap that you have between pusing the gas pedal and the car actually responding to throttle input.
infact, I have to do it again soon. I don't know why, but does the thing actually come loose over time?
Old Jan 10, 2006
R1Style's Avatar
Quicker throttle response by taking out the slack.
Allows the butterfly to fully open when you're WOT.
Old Jan 11, 2006
SEVYN's Avatar
SEVYN is an unknown quantity at this point
can anyone take a pic of where it is located? i checked the DIY.. but i still cant figure it out.. thanks
Old Jan 11, 2006
Nick's Avatar
Formerly 2blu
That was the first mod that i did and i loved it. But u get used to it after a while.
Old Jan 11, 2006
Old Jan 11, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
These should help you:
Basically on the driver's side behind the engine (the blue hose and reservoir will not be in your engine). The air intake (or stock filter box) to the left and brake fluid reservoir at the top right.
You will have two cables if you have cruise control. The cable to the bottom of the picture is the cruise, the cable with the pink nut is the throttle cable.
Old Jan 11, 2006
bobsagator's Avatar
Well, Gearbox beat me to it...
Old Jan 11, 2006
_Viper_'s Avatar
actually when i did mine it acted almost like a turbo ...
cheapest mod yet
Old Jan 11, 2006
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
^ mine sounded like one,. Seriously the car will be a little more responsive.
Old Jan 11, 2006
micks7thgen's Avatar
micks7thgen is an unknown quantity at this point
yeah i never thought of doing this before and it took me literally 1 minute to do it now i barely touch the pedal to make it go i love it.
Old Jan 11, 2006
jasonlab's Avatar
jasonlab is an unknown quantity at this point
first of all mine is pretty rusty so its hard to get the bolt tighter. but do i need to loosen the bolt on the left side?
Old Jan 11, 2006
genexrocket's Avatar
yea, one of the first mods to my car, do it~!
Old Jan 11, 2006
jasonlab's Avatar
i loosen the right one so i can tighten the left one but the left one is stuck. is there anything else that i can use other than wd40
Old Jan 11, 2006
any kind of grease, oil will do. Heck, you could even use cooking oil if you want, but that is nasty plus it is really thick.
Old Jan 11, 2006
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
Never looked into this, but my throttle response is off. At a light, I have to give a little more than feather just to get the car rolling. I bet its contributing to my low MPG's, since I am giving the car more gas to get it going.
I'm going to give this a try tomorrow.
Old Jan 11, 2006
it isn't that drastic. you won't notice higher mpg. that tends to be more integrated into your driving style. if you like to launch quickly when you're stopped than that is what is lowering your mpg.
Old Jan 11, 2006
slick's Avatar
that little dude
Thats my problem, I do launch quickly, I give too much gas because my car feels overly sluggish. I'll try the throttle cable adjustment, I can always revert back to the way it was.
Old Jan 11, 2006
asian's Avatar
asian is an unknown quantity at this point
By doing this does it have any adverse affects on your drivetrain?
Old Jan 11, 2006
no all you do is tighten the cable that connects your gas pedal to the throttle body. so that when you press the gas, there won't be a pause in acceleration as the slack tightens up. actually the factory spec calls for 0.5 inch of slack but when i did mine it was more like 2 inches. if its too loose, you won't be getting all the power that the engine has because the throttle plate will never open fully when the gas pedal is floored. just make sure there is a few mm of play when you tighten it so that the throttle body doesn't stick open. you'll know because the idle will be sticking when you press the gas.
Old Jan 12, 2006
05_ CivicJDM's Avatar
Cool, you learn something everyday on this site!! Thanks guys...
Old Jan 12, 2006
DDragon7's Avatar
Also my first mod, and pretty easy to do and it responds better when tapping the gas to rev-match.
Tyler93
Mar 20, 2016 09:03 PM
velozp
Dec 13, 2015 11:28 AM
IronFist
Sep 25, 2015 07:13 PM
2.0.0.2
Sep 14, 2015 06:38 PM
Bricoleur
Sep 9, 2015 12:30 PM
