General 8th & 9th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Whining noise
Old May 16, 2021
Foxmotofan15's Avatar
Foxmotofan15 is an unknown quantity at this point
Whining noise
Okay I need some advice, cause I've about lost it at this point.I have a 2009 honda civic dx 1.8 sedan. So I've got a whining noise coming from the belt drive.Im 100% sure it is coming from the belt drive region because once I took the belt off the noise stopped completely. Alternator is less than a year old, and just today I replaced the belt tensioner(with new belt) and I also replaced the A/C clutch because the pulley was seizing up and causing my belt to smoke while I was driving.Good new A/C works now,bad news is the noise is still there and I'm at a loss at this point. Anyone that has had any experience with this issue that could steer me in the right direction would be greatly appreciated.thank you!
Old May 16, 2021
FRSam's Avatar
Click Here
Re: Whining noise
Are you sure you haven't just overtightened the belt(s)?
Old May 17, 2021
Colin42's Avatar
Re: Whining noise
​​​​​​ Automatic tensioner on these ones,
Check the tensioner pulley and idler pulley, cheap and easy to replace if it's one of them
Old May 17, 2021
FRSam's Avatar
Click Here
Re: Whining noise
Thanks for the correction
Old May 17, 2021
BrotatoChip's Avatar
Super Moderator
Re: Whining noise
Take the belt back off and spin each pulley by hand. Which one makes noise?
Old May 17, 2021
Re: Whining noise
When the noise originated i did that exact same thing before I had bought any of the parts.The a/c clutch pulley was grinding real bad if you spun it by hand but that was the only one.It almost sounds like the noise a power steering pump makes when its going bad when you turn the car but it doesn't make that sound when I turn the car.
Kyleprice2118
General 1st - 5th Gen
Oct 26, 2019 08:58 PM
mistororange
Apr 4, 2014 10:39 PM
mcallis22
Apr 9, 2012 07:04 PM
dalaw
Sep 22, 2011 11:11 PM
calpolyarc
Sep 1, 2011 12:22 PM
