General 1st - 5th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Belt Squealing Noise!
Old Oct 26, 2019
Kyleprice2118's Avatar
Kyleprice2118 is an unknown quantity at this point
Question Belt Squealing Noise!
Yo! Whats up y'all, For some reason, there is a squealing noise coming from the belt on the engine belt system. I'm not sure if its the tensioner, or the alternator causing it, but it doesn't happen often. It comes then goes away in a few minutes. Usually following an electrical fluctuation. For example, the last time it happened, it made that noise, it went a way in a minute or two, then when i started to drive my radio turned off then back on, and my speedometer went to 0 and came back up to normal. As far as i am aware, alternators don't slowly go out. They usually work, or they stop working. I think it might be the belt tensioner pulley. How can i tell?
1995 Honda Civic DX Coupe.
All opinions welcome!
Old Oct 26, 2019
GolNat's Avatar
Prelude Owner
Re: Belt Squealing Noise!
Check to make sure the alternator is tight and inspect the accessory belt. They usually slip when it's cold out and go away when the engine warms up. With the belt off you can manually spin the pulleys and tensioner to make sure they are good.
Old Oct 26, 2019
Okay.. I will. Thank you very much
eager2learn
18
May 29, 2017 06:01 PM
sean2012
Dec 20, 2012 01:25 AM
dalaw
Sep 22, 2011 11:11 PM
calpolyarc
Sep 1, 2011 12:22 PM
lexxie
Oct 16, 2009 12:12 AM
