1999 Civic EX, Noise in Engine bay
Old Apr 4, 2014
mistororange's Avatar
mistororange is an unknown quantity at this point
I've had this car for about a month now, and have noticed a slight "whurring" noise coming from the engine bay, timing belt side. doesn't do it at idle, but from 1-2k you can hear it, it "whurrs" like a bearing or a belt. I found a video on youtube, that has kinda the same sound, anyone else have experience with this? The timing belt was supposedly changed recently, I took the belt cover off, belt looks good, doesn't seem to tight or anything, not that you can really tell I suppose. But was hoping maybe this could be some other belt, and not a timing belt or water pump?
Anyway just curious of anyone else had this noise before thanks.
Here is link to video of someones that sounds like mine
[YOUTUBE]https://www.youtube.com/watch?v=APvGmJKG9Vg[/YOUTUBE]
Old Apr 4, 2014
Re: 1999 Civic EX, Noise in Engine bay
I'd say to remove accessory belts, one at a time, and see if the noise goes away or is still present.
If you, for example, remove the AC belt and run it and the noise is gone, then investigate which part is noisy. Spin the pulleys, listen for bearing noise or roughness as they spin. (The adjuster pulley is known for having loud/rough/noisy bearing.)
Repeat until noise disappears or all belts are off and noise is till there.
If you get all 3 belts off (assuming you have AC and 3 accessory belts) and the noise is till present, then the noise is probably in the timing area.
Timing belt too tight? Aftermarket belt? Tensioner pulley? IDK, can't tell from where I sit.
HTH
Xuhme
21
Aug 7, 2023 03:40 PM
usajags84
May 10, 2015 08:11 AM
smmahan
Apr 15, 2015 08:17 PM
locozoko
Apr 6, 2002 09:00 PM
2k1Vtecivic
Nov 10, 2001 06:23 AM
