no cel 97 hx
Old Apr 6, 2014
sportster883h's Avatar
sportster883h is an unknown quantity at this point
no cel 97 hx
Have codes in the computer. auto zone pulled them. DON'T have a cel. bulb is good swapped it with the hi beam. any ideas where to start with fixing it? will fix issues with codes also but won't pass pa emissions with out light working
Old Apr 6, 2014
Re: no cel 97 hx
Wiring diagram.
Find the wire at the PCM that controls the check engine light. See if you can operate the light manually from the PCM connector: using a jumper wire, ground terminal A18.
The answer to that determines the next steps.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Luluharp
Sep 27, 2015 11:56 AM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
jpat21
Sep 3, 2015 11:32 PM
