Stage 1 Cams
Old May 8, 2013
  #91
maxtierney's Avatar
EM2ti
Re: Stage 1 Cams
LOL. Cleanest part of the car, everything else is dirty.
Old Aug 3, 2013
  #92
mac25's Avatar
Dr Krieger of Modification
Re: Stage 1 Cams
crower stage 1 is in hand...4 days off...wish me luck!
Old Aug 3, 2013
  #93
mac25's Avatar
Re: Stage 1 Cams
well took me about 10 hours but she's in and ran at idle, i'll take her for a run then post some feedback, wish me luck!
Old Aug 4, 2013
  #94
Re: Stage 1 Cams
I just now realized what your sig meant. Holy crap I'm slow.
Get the CEL nonsense figured out?
Old Aug 5, 2013
  #95
mac25's Avatar
Re: Stage 1 Cams
hahaha lol. ya my scanner is not working, so i have to wait until tomorrow and use one at work. it sucks though it seems right when the cam starts feeling good the CEL comes on. i tryed an ecu relearn and she did good for a while then i took her up to 6000rpm in second and the cel cam on again.
Old Aug 6, 2013
  #96
Re: Stage 1 Cams
You triple-check that the timing was good and that every sensor was hooked up properly?
Old Jan 24, 2014
  #97
nsrhonda89's Avatar
nsrhonda89 has a spectacular aura aboutnsrhonda89 has a spectacular aura about
Re: Stage 1 Cams
[QUOTE=maxtierney;4639798]My next mod will be D16Y8 Intake Manifold.
Old May 28, 2014
  #98
em2 10's Avatar
em2 10 is an unknown quantity at this point
Re: Stage 1 Cams
Where can i purchase a stage 1 cam for my 04 civic ex?
Old May 28, 2014
  #99
Re: Stage 1 Cams
^ I think we answered that on your thread... If you don't even bother to read, there's no reason to reply.
and you are in the internet... search!!!!
Good for nothing post will be deleted in a few days.
Here, your OWN thread:
https://www.civicforums.com/forums/2...t-upgrade.html
Here, the post telling you where to buy them:
Originally Posted by GolNat
A more aggresive cam will allow for the valves to open up more. Check out Crower cams.
Coilovers check out, Progress, Tein, Ground Control, Buddy Club. Various distributors carry these products. Two that cater to the 7th gen are Dezod and Corsport.
http://www.dezod.com
http://www.corsportusa.com/store/catalog/index.php
Old Mar 10, 2016
  #100
MassCivic's Avatar
MassCivic is an unknown quantity at this point
Re: Stage 1 Cams
My stage 1 cam is scheduled to arrive on the 15th!
Trying to make a list of what to replace while I install it. Did a hg/ timing belt job about 40k ago including way more gaskets and seals than necessary.
So far I've come up with the crank seal, since it wasn't included in the Honda kit and I never got one. Probably gonna swap in a new crank pulley as well, mine has a tiny chip on one of the grooves and has 222k on it.
Also going to put in new cam cap and seal, cap seems to be leaking again.
I also still have a brand new set of valve seals from the gasket kit. Would it be worth doing them at this point? 222k but no smoke from the exhaust or anything.
Anything else I should be changing out while im in there?
Old Mar 10, 2016
  #101
Re: Stage 1 Cams
just realized i have not post the mileage I am getting with the cam still in there
this is the best ever trip, some 25 miles with HWY (70 MPH), so local (55 MPH) and city (35 MPH) - very short stretch
second best ever - today, so after the header install - it still can do it!
Old Mar 10, 2016
  #102
Re: Stage 1 Cams
the valve seals... not sure, i did not do them, but i am still at 120k
the crank seal - i think mine is starting to leak, should have done...
I think you got most of them already covered?
Old Mar 10, 2016
  #103
MassCivic's Avatar
Re: Stage 1 Cams
Right on, been through enough parts diagrams now I shouldn't be missing anything!
Just wish the HG kit had included it in the first place... Cam seal but no crank seal!?
I suppose I'll do the valve seals if I can find the tool, otherwise I put it off again.
Old Mar 22, 2016
  #104
MassCivic's Avatar
Re: Stage 1 Cams
Dropped in the stage 1 today, have to finish reassembly and adjust valves tomorrow!
Old Mar 23, 2016
  #105
Poopies's Avatar
Super Moderator
Re: Stage 1 Cams
Nice! Any advice for the install?
Old Mar 23, 2016
  #106
Re: Stage 1 Cams
take your time. ****'s stupid easy to do.
Old Mar 23, 2016
  #107
Poopies's Avatar
Super Moderator
Re: Stage 1 Cams
I'm mainly worried about the timing belt and such... I've never dealt with it before.
Old Mar 26, 2016
  #108
Re: Stage 1 Cams
take a look into the timing belt link - i posted my mishaps there
Old Mar 27, 2016
  #109
Re: Stage 1 Cams
Timing belt is much more intimidating before you first mess with it. I'll admit, at first I was scared to touch it, now I have no qualms about taking it off and putting it back on if I need to.
Old Apr 4, 2016
  #110
MassCivic's Avatar
Re: Stage 1 Cams
Just take your time, triple check your timing marks when finished and have a shop or repair manual handy for specs.
Follow the timing belt DIY and you should be in good shape.
When you remove the valve train, leave the bolts in place so it doesn't start to walk itself apart. Put it on a towel on a bench and place the valve cover over it to keep everything in place and covered.
Make sure your alternator bolts are properly tightened!
This mod was well worth it, it pulls much harder in the higher rpms and feels peppier all around. Going to switch back to my old 4-1 header w/cat soon to see if the added back pressure helps out any. Currently running a DC 4-2-1 and not really enjoying the raspiness and intermittent O2/AF sensor cel's.
ricer_em2
May 11, 2016 08:09 PM
beanhead
Sep 24, 2015 12:04 PM
OptimisticWay
Sep 18, 2015 09:37 PM
Juanb24
Sep 15, 2015 12:39 AM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
