bolt ons = hp ?
Old Nov 30, 2004
  #31
bgoetz's Avatar
bgoetz is an unknown quantity at this point
Originally Posted by gearbox
I'll never accept it! I just broke the 100whp mark (dyno at 100.7 whp) and I'm not stopping there. Next goal, 110whp altho that's set a bit high.
what dyno is that on??? mustangs dynos are always low as hell. If it is not a mustang dyno then maybe you should ask the guy that got 125whp what he has and then do the same.
Old Nov 30, 2004
  #32
kornsined's Avatar
You know what's kinda weird is that i don't think that guy had the best products available.
Originally Posted by 02boostlessCIV
i have obx headers, megan racing cat, ghetto catback, stock rims(when dynoed)
HE also stated he had a lightened flywheel and clutch but i'm not to sure about that adding too much HP.Maybe he just found the right combination.
Old Nov 30, 2004
  #33
bgoetz's Avatar
Originally Posted by kornsined
You know what's kinda weird is that i don't think that guy had the best products available. HE also stated he had a lightened flywheel and clutch but i'm not to sure about that adding too much HP.Maybe he just found the right combination.
I think that he has the same flywheel/clutch combo that I have. The clutch does not add any hp unless your oem was going out. The flywheel prob added the most hp due to less rotational mass directly at the crank. I felt a good gain with mine.
Old Nov 30, 2004
  #34
I have an auto, that's the problem. It was a regular dynojet not mustang.
Old Nov 30, 2004
  #35
bgoetz's Avatar
yeah I didn't want to say anything ....
I still thought that it was only around a 3% loss. Maybe it just does not mod as good
Old Nov 30, 2004
  #36
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
guy that posted. Take that header exhaust money and go get some nitrous. ~$600+ for a wet kit and you can run 35 shot - 50 shot. and if ur crazy for the NAWZ; upgraded internals and crap outta give u 75-100 shot RELIABLY. either way, you will still be faster than if u had got the base rsx k20. with a 100shot, you would pwn a k20(type s) 7thgen civic no problem.
edit: i would get nitrous, but i think its like $50 bucks a full bottle and knowing me. i will need one about every week.
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
pilebuck13
Sep 21, 2015 10:45 PM
amrhamed
Sep 21, 2015 02:56 PM
