HONDATA for D17 - 0%
Old Oct 26, 2004
  #61
tcostello's Avatar
tcostello has a little shameless behaviour in the past
Originally Posted by ati9700pro
i wonder if they will raise the rev limiter?
Yeah, make my s**t quit droppin' off at 6500!
Old Oct 27, 2004
  #62
silverem2's Avatar
6500? I can go to 7000 and my limiter doesnt kick in till 7100....hmm
Old Oct 27, 2004
  #63
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^^ your tach is off
Old Oct 27, 2004
  #64
kezay's Avatar
kezay is an unknown quantity at this point
I am definately waiting to see if this happens....
Old Oct 27, 2004
  #65
tcostello's Avatar
Not worried about the rev limiter, there's NO POWER over 6400!
Old Oct 27, 2004
  #66
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
7000 redline????
Old Oct 27, 2004
  #67
Green Civic's Avatar
The red line is at 6800 rpms. The tach in the cluster just looks like it goes to 7000 rpms.
Old Oct 27, 2004
  #68
mykungfuisthebest's Avatar
mykungfuisthebest is an unknown quantity at this point
It will be a big help for NA bolt ons too, with I/H/E mild p&p, mabie a cam gear and underdrive pullys id say adding this might ad up to 20 hp but thats being VERY generous...
but aside from max hp gain, you power curve will be much better than stock which will lower 0-60 or quarter mile times
Old Oct 27, 2004
  #69
VTECTypeR's Avatar
my automatic can go up to 7,000 rpms if I hold it in the gear
Old Oct 27, 2004
  #70
opto_isolator's Avatar
Wanna bet? Take a look at my dyno plot for my turbo - the power goes all the way to redline....Raise the limiter and I can take advantage of it...
Old Oct 27, 2004
  #71
Zzyzx's Avatar
Autocross Junky
He should have said "thers no power past 6,500 RPM in an otherwise stock engine" If you signifigantly alter the torque curve, then sure, moving the rev-limiter may help, otherwise your just wasting time and accelerating slower.
Old Oct 27, 2004
  #72
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
I want it! Now all we need is some one to make cams and other internals and we are set! Unless some one already does and i'm uninformed?
Old Oct 27, 2004
  #73
tcostello's Avatar
Thanks for covering that for me. I surely was not refering to those of you lucky eneough to be boosted. It's actually nice to know that if I go boost I will make power up there, It would surely help my maniacly high speed on ramp runs
Old Oct 27, 2004
  #74
pnoyster2k1cvic's Avatar
Balut Eating Champ
i can't wait! i can't wait! my oh my! (me screaming like a girl cuing homer simpson) eh hhihihihihhii!
Old Oct 27, 2004
  #75
R1Style's Avatar
But the question still remains... will this work for both the D17A1 and D17A2?
Old Oct 27, 2004
  #76
silverem2's Avatar
are you sure about that? I can bring it well into the 7000 like 7100 it kicks in...
Old Oct 27, 2004
  #77
Blahman2's Avatar
I have a D17A2 in my 2004 civic... What civic's have the D17A1?
Old Oct 27, 2004
  #78
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
^^ the lx and dx models
Old Oct 27, 2004
  #79
R1Style's Avatar
D17A1 = Non Vtec
D17A2 = Vtec
Old Oct 27, 2004
  #80
loriant's Avatar
loriant is an unknown quantity at this point
bump so i can find it agian.
Old Oct 28, 2004
  #81
usafstud's Avatar
i think maybe. cause when they did the initial test, theyturned the vtec function off on the program cause our car doesn't have a vtec solenid or something like the k20 and the b's
i don't want to bug hondata with questions cause they don't know everything yet. we will just have to wait and see, I am(and its my car)
Old Oct 28, 2004
  #82
silverem2's Avatar
whens the eta till we will at least have a update, wont you be gone somewhere?
Old Oct 28, 2004
  #83
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
because your tach is off by 100-200 rpms
Old Oct 28, 2004
  #84
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
CARB Legal, yes and no.
The benefit of using Hondata is that the car is running on a stock ECM. It is only modified to allow the altering of the car's parameters. But everything still works, including the OBD II diagnostics. So if the car had the stock program installed, the car would run as stock. And it should pass the smog test.
Now, when you change one thing it is no longer running a CARB legal program. It may still pass smog, but it is not legal. Since the CARB certification runs with a set program, changing it voids the certification. So this part will never be CARB certified since it is a modification to deviate from the original programming.
But this is great news. Hondatas run cars very well, even with turbos or superchargers, the cars idle and run like stock, and then when under load, really perform. So you could boost, or add bolt ons and tune to maximum performance.
Old Oct 28, 2004
  #85
Yeah - that's what I'm waiting for! The emanage is a hack, plain and simple. The injector change feature of the k-pro would alleviate half of our problems with check engine lights, and idling issues! I hope it works out!
Old Oct 29, 2004
  #86
zachgeyer's Avatar
is it done yet ?
Old Oct 29, 2004
  #87
K20A_Wanabe's Avatar
K20A_Wanabe is an unknown quantity at this point
Are you really gona gain that much more that the vafc II with the hondata ? cause if so i'm gona jump right on it.
Old Oct 29, 2004
  #88
djmota's Avatar
Yes you would. No cel's no playing with map sensor readings to trick the ecu to run rich or lean, being able to change timing being able to build a fuel and timing map over stock redline, the list goes on and on. Hondata is the ish.
Old Oct 29, 2004
  #89
dezod's Avatar
7thgen Power Maker
The Hondata K-Pro is hands down, one of the nicest EMS I have seen thus far...It honestly puts the E-Manage to shame.
Old Oct 29, 2004
  #90
So with intake headers exhaust hi flow cat i woudl probaly gain around 20 hp ?
