Ground Wiring?
Old Oct 20, 2004
  #61
AceKicker's Avatar
AceKicker is an unknown quantity at this point
ok now another question I saw that bridge motorsports posted that they use a fully metal distro block because it will help conduct the electricity better. What is the truth to this. I mean can I by a distro block at my Stereo place? or can i go buy any type of distro block?
Old Oct 20, 2004
  #62
sevenplaces's Avatar
I want a TSX!
sevenplaces is on a distinguished road
Originally Posted by wonderz
i guess this proves that our stock ground wires are thick enough that we don't need to upgrade it to 4ga.
what year's your car btw? notice any rusting in the stock ground points?
01 coupe...no rust
Old Oct 20, 2004
  #63
wonderz's Avatar
wonderz is on a distinguished road
Bridge Motorsports kit uses a aluminum distro block, which is better than steel, however, any aftermarket distro block will be better than the one they give you. 'cause usually aftermarket distro blocks comes in either Gold plated or Platinum plated which are a lot better than aluminum. So yes, generally any distro block u buy from a local stereo place will be better than the one provided from the bridge motorsport kit.
Old Oct 20, 2004
  #64
wonderz's Avatar
Originally Posted by sevenplaces
01 coupe...no rust
yea, i think ppl that actually notice some different is due to the fact that they might have some rust in their connection due bad weather or other reason. maybe you can try ground to more places to see if you notice anything. wouldn't hurt to try.
Old Oct 20, 2004
  #65
memorex's Avatar
memorex is an unknown quantity at this point
So me getting shocked everytime I close the door is due to bad grounds? Im not as educated on this as everyone else seems to be..
Old Oct 20, 2004
  #66
CivicHX01's Avatar
here's my kit...
http://www.7thgencivic.com/forums/sh....php?p=2094237
It's DIY and i like it... i noticed quicker throttle response, crisper sound from the radio... i also like how it looks under the hood...
i don't think i gained any hp from it though... but i know my whole car is grounded pretty well now...
Old Oct 21, 2004
  #67
gtracing's Avatar
TeLLy is my daddy
gtracing is an unknown quantity at this point
uh....
*Warning...Thread overload!*
holy ****...well anyways, yea, it's just a ground kit..we don't need to get so technical...hahahahahahaha besides, please remember, we drive civics (1.7EL in my case) but yea...slow piece of junk....
anyways...well here's my life story...
uh....i did 1 year of mechanical engineering (which we also needed to learn electricity, that's why i sorta have an idea about electrical stuff), then i dropped it and took civil...now in my second year of that, hopefully will graduate....so reddawnman, ur way above my league..hahaha
so um...in conclusion, if u want simple dummy term, just read my posts....
if ur hardcore, read reddawnman's post....
man, thread officially hijacked by reddawnman...<-u da man!!!
anyways, yea, i have an apexi ground kit stabilizer thingy majiggy....it looks good, does absolutely **** all, paid an arm for it, and absolutely love it!
the end
Old Oct 21, 2004
  #68
AceKicker's Avatar
Hey GT where did you buy the APEX one at. I wanted to read up on it I couldnt find it though.
Old Oct 21, 2004
  #69
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
Didn't mean to steal your thunder / hijack the thread I hope you do well in civil eng, it is very cool to build things that will last forever. My hope is that a song I write or a recording I'm on might be something that affects someone forever.
U da man!
Old Oct 21, 2004
  #70
wonderz's Avatar
you are all "da man"!!!
man, this ground kit thing is costing me a leg or an arm.... high quality stuff are expensive
Old Oct 21, 2004
  #71
reddawnman's Avatar
Actually, it's due to good grounds
A human being stores electrical charge. Our nerve impulses are electrical, and our skin is like sheeting on a wire, insulating our body and keeping the charges wherever they belong.
If you've ever seen a spark jump, you know that if the voltage is big enough, electricity will jump through the air to discharge a voltage. If you wear rubber shoes (good insulator) and are moving / rubbing in the seat with like wool pants or anythign with silk in it, you create a static electricity charge around yourself. The reason you don't immediately discharge and have electricity flowing through you is because of your skin and those rubber shoes making you a good insulator, and because the human body has a high "resistance" to carrying electron flow. Now, normally you aren't close to a "ground" or something that can return the energy to the natural state inside the car. However, once you touch metal (good conductor) then you make a path with very little resistance to the battery / point of 0 voltage (Because metal is a great conductor), and bam, spark and the "ouch" from the person.
This is the same reason that it's very safe to be in a car in a thunderstorm. if you get hit with lightning, the conductior is the metal body of the car that is around but not going through you (The path from air ->Car -> ground state is easier to pass through than air -> your poor body -> ground state, threrfore you are unharmed as the lightning flows through the car to the ground.
Make any sense? if not, thats my bad, sometimes I DO overcomplicate stuff.
Old Oct 21, 2004
  #72
AceKicker's Avatar
Well I really think that the seat causes alot of creating that shock. Because i guess the material they use just creates alot of static. When I changed my seats to sparco I stopped getting shocked when i got out of my car. But I use to get shocked badly too. I mean when you heard that pop my friends heard the pop on the other side of the car i mean it was loud and strong. lol.
Old Oct 21, 2004
  #73
gtracing's Avatar
TeLLy is my daddy
yea, i dunno why either, but for some reason, oem clothes always has so much static....maybe it's the way it was put together or something...machines maybe? i dunno
but yea, um...for the apexi thing...um....i dunno, i heard there's some info on the apexi site now...if u wanna do a read up on it..i seroiusly don't know where to get info dude...i'm sponsored by an aftermarket company in hk called GT Sport, it's actually one of the biggest in hk, and they gave it to me for cheap...around 300cdn shipped..and retail was something like 500cdn? and now i believe they dropped the price...it's like 300cdn now...so i might be able to get it cheaper..i dunno, i've had mine for about 6-7 months now and i absolutely love it because i placed it above the battery and people who walk by can see the apexi symbol glowing under the hood (they can see through the crack between the fender and hood), it's a cool little unit...definitely felt the throttle respond faster....and much much smoother acceleration throughout the entire powerband...
Old Oct 21, 2004
  #74
AceKicker's Avatar
Yeah I alreday read the info on APEXi I just cant find it anywhere else. I first saw it in a magazine some car had it pretty hot looking. I didnt know it glowed taht is cool. Does the shop have a website where you can buy it off of? and what is the conversion rate right now from canadian money to US money?
Old Oct 21, 2004
  #75
gtracing's Avatar
TeLLy is my daddy
um...the site is http://www.gtsport.com.hk/, but you can't buy it off the site....and there's not really much info on the site either...the conversion rate from canadian to us money is 0.8 or something like that...
just go on www.xe.com for an online conversion calculator
and yea, there's a red led inside the stabilizer and it glows 24/7 unless u unplug it from the battery
Old Oct 21, 2004
  #76
wonderz's Avatar
what is actually inside the box in the apexi thing? is it the same thing as the Hyper Voltage System?
Old Oct 21, 2004
  #77
gtracing's Avatar
TeLLy is my daddy
i dunno what's inside, but i'm guessing so...
hondadriver95
Jul 13, 2015 09:43 PM
Jul 12, 2015 11:54 AM
JUNITO
Jul 9, 2015 08:36 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
