Engine / Torque Dampener - anyone using this
Old Apr 1, 2004
  #61
OsOBooSTeD's Avatar
OsOBaNNeD
as for the second bolting place.... distinctive.. lol that is a bad idea .. thats what? the brake fluid? the metal there is paper thin... go higher try the strut or even the motor mount
Old Apr 2, 2004
  #62
DistinctiveBP's Avatar
Shows No Remorse
DistinctiveBP is an unknown quantity at this point
thats what i was thinking. maybe getting like a bracket made that can come down from where on of the bolts that you bolt your strut brace to.
Old Apr 2, 2004
  #63
blouisgod's Avatar
Life Begins > 6800rpms
Im saying, why bolt this thing to the motor mount? If you look on the spoon dc5, the brace mounts to the firewall to a point on the head.
Old Apr 2, 2004
  #64
PunkingCivic's Avatar
I need TP for my bunghole
there has to be a way for abs and non abs civic to have this work.
don't you feel like an engineer making a new part for the car, LOL out of fustration.
Old Apr 2, 2004
  #65
IronFist's Avatar
What's an Engine / Torque Dampener supposed to do?
Old Apr 2, 2004
  #66
it dampens the back and forth of the motor so that it allows for better power response from the engine.
Old Apr 2, 2004
  #67
thecheat's Avatar
thecheat is an unknown quantity at this point
what about going from the water pump housing on the pasenger side of the engine to the back strut mounting bolt. Its a long gap to bridge but it should work for all trim levels with an intake. You just have to make the brackets bigger.
Old Apr 3, 2004
  #68
IronFist's Avatar
Does it really? Or does it just make more power in theory like grounding wires?
Old Apr 3, 2004
  #69
thecheat's Avatar
This is a really comon mod in the VW rabit comunity and they have found it to be a substantial improvment over ruber mounts without the noise and vibration issues of PU mounts. It should be a good mod. I am working on a way to measure how much movement there really is so I can see how much range it needs to have. If I figure anything out I will post it here for you guys
Old Apr 4, 2004
  #70
blouisgod's Avatar
damn it, someone come up with something.
Old Apr 4, 2004
  #71
thecheat's Avatar
Im getting my tires and wheels all finished this week and the alignment done friday. then I will have some more time to devote to this damper idea.
Old Apr 5, 2004
  #72
to get an idea of engine movement, place the car on jack stand and have someone run the car through the gears and stand at the side of the car and view.
Old Apr 5, 2004
  #73
IronFist's Avatar
^ Does that sound dangerous to anyone else?
Old Apr 5, 2004
  #74
thecheat's Avatar
yes and it wont give you good results because the engine wont have any resistance. I'm going to make a movement recording ruler and try that. Its pretty simple, metal ruler, whiteout, hose clamps, duct tape. should work fine. that way I can test it while driving.
Old Apr 5, 2004
  #75
RiceBuRNeR's Avatar
Turbo Member
Well I just bid on one of the smaller universal ones on ebay. Im going to fabricate some bolt on mounts if possible and then offer them to everyone.
Old Apr 5, 2004
  #76
thecheat's Avatar
cool. where are you thinking about puting it?
Old Apr 5, 2004
  #77
RiceBuRNeR's Avatar
Turbo Member
I want to make a ring mount that will bolt on the strut tower (w/ a spacer for the other side to keep it even) and then I have to find the best spot on the head and then weld up a bolt on bracket, so Im not totaly sure yet.
Old Apr 6, 2004
  #78
IronFist's Avatar
before and after dyno's please
Old Apr 6, 2004
  #79
thecheat's Avatar
I doubt it will show a differance on a dyno. What it should do is help control power delivery and chasis weight shifts. Im actualy mor interested in it for heavy braking then power reasons.
Old Apr 7, 2004
  #80
RiceBuRNeR's Avatar
Turbo Member
exactly, you wont actualy make more power, but you will put it down to the pavement better. Just like my 8 lbl flywheel, didnt add any power but I made it sooner.....damn dyno ****'s.....j/k
Old Apr 7, 2004
  #81
TeLLy's Avatar
Yes, it's an Acura EL
And if you do, you will have my money very very quickly.
Old Apr 8, 2004
  #82
blouisgod's Avatar
Word up.
Old Apr 9, 2004
  #83
cdmx's Avatar
Awesome!
well i bid on one, dont outbid me! you know who i am
I may make my own bracket
Old Apr 9, 2004
  #84
IronFist's Avatar
Interesting thread.
Old Apr 9, 2004
  #85
When I made this tread I didn't expect this much particitation.
This is great. Has anyone designed anything yet?
Old Apr 9, 2004
  #86
cdmx's Avatar
nope....
Ill wait for the dampener
Ive got an idea...it might/might not work
making a bracket from the strut tower bolts moving that lil resivoir and making another bracket to hold the dampener to those two large bolts right next to the engine.
Old Apr 9, 2004
  #87
cdmx's Avatar
Eh looking at this
I think its a better itdea to drill some holes in the strut tower
But that lil resiviour needs to be moved. I get my digi cam back in like 2 hours...my parents are almost home
Old Apr 9, 2004
  #88
cdmx's Avatar
We definetly need to fabricate a bracket VERY smilar to that one on the right
should be easy....i hope my blow torch is up to it...and my hands...haha
One more thing....what kind of metal should the bracket be made out of....pretty thick aluminum?? or is that not strong enough
Old Apr 9, 2004
  #89
cdmx's Avatar
I took a bunch of pics of the engine bay
Old Apr 9, 2004
  #90
blouisgod's Avatar
Make something damn it!!!!!
