Engine / Torque Dampener - anyone using this
Old Apr 16, 2004
  #121
IronFist's Avatar
Um yeah I don't have a welder so if someone wants to do the welding or whatever for me and sell it that'd be rad.
If it works, of course.
Old Apr 16, 2004
  #122
PacSmalls's Avatar
PacSmalls is an unknown quantity at this point
i hope it works
Old Apr 16, 2004
  #123
cdmx's Avatar
Thanks i think ill go to pep boys see if they have a welder i can rent
Old Apr 16, 2004
  #124
PacSmalls's Avatar
id like to rent a welder sometime ;\
Old Apr 16, 2004
  #125
blouisgod's Avatar
Life Begins > 6800rpms
Damn, I dont want to have to weld this thing on.
Old Apr 16, 2004
  #126
blouisgod's Avatar
BTW I stickied this thread for easy access.
Old Apr 16, 2004
  #127
PunkingCivic's Avatar
I need TP for my bunghole
your the ish
I had it in my sig for quick reference.
As for a comment above, I don't think they will weld to to the body just make some braket peices and weld those together.
Also here is a site with low priced tools and other stuff.
http://www.harborfreight.com/
They have welders from $79.00 and up
Old Apr 16, 2004
  #128
IronFist's Avatar
Old Apr 16, 2004
  #129
cdmx's Avatar
THAT SITE IS THE **** PUNKINGCIVIC!!
I want this!!! http://www.harborfreight.com/cpi/cta...emnumber=46299
Old Apr 17, 2004
  #130
IronFist's Avatar
^ Whoa!
Old Apr 18, 2004
  #131
cdmx's Avatar
Hows yours comin along RiceBuRNeR
Old Apr 19, 2004
  #132
01EXtc's Avatar
01EXtc is an unknown quantity at this point
Those are sweet. Ive been looking around and havent seen any for the infamous d17.
if only our motors had enough power to need one...lol
but for the turbo guys this would be nice
Old Apr 20, 2004
  #133
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I've got the Energy Suspension motor mounts, it's a 2 piece kit, front and rear mount. I'm about to put them in when my DH pulley spacer comes in, you know how that is? I ordered them from SUMMIT, they came out to $30 even and had to be special ordered for Energy. They come in red and graphite I got red. Kinda off topic but kinda on topic too.
Old Apr 20, 2004
  #134
blouisgod's Avatar
Yah, bushings help but work more so for the bottom of the engine. The damper is supposed to help the upper portion of the engine.
Old Apr 21, 2004
  #135
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
actually i was surprised, our engines travel quite a bit. try popping the hood while its on and revving it up with the throttle cable from inside the engine bay. this should help even for stock engines.
Old Apr 21, 2004
  #136
IronFist's Avatar
How does keeping the engine still make more power?
Old Apr 21, 2004
  #137
blouisgod's Avatar
Not make power, transfer power.
Old Apr 23, 2004
  #138
IronFist's Avatar
So what, it reduces the amount of lost power? How does it work?
Old Apr 24, 2004
  #139
IronFist's Avatar
Well, I was gonna bump this thread, but it's already sticky. hehe.
Old Apr 24, 2004
  #140
blouisgod's Avatar
I sticky
Anyone with anything? How are the people who ordered one making out?
Old Apr 24, 2004
  #141
blouisgod's Avatar
The idea is that by supporting the engine and eliminating back and forth motion, more power is transfered through the driveline. Think of when you are shifting hard; the engine is under load, the load stops when you depress the clutch, and the engine rocks forward, then when you shift and hit the gas again, the load on the engine forces it back, creating a lose of power through extra motion. This acts as a brace to eliminate that motion. The idea behind it is simple and I'm not really sure if it works, but it looks cool on the Ep3's and Dc5's.
Old Apr 27, 2004
  #142
IronFist's Avatar
B U M P
Old Apr 27, 2004
  #143
cdmx's Avatar
I kinda gave up...i dont have the right materials
Im just waitin till i find the right piece of metal that will work
Old Apr 27, 2004
  #144
blouisgod's Avatar
damn people....lets go
Old Apr 29, 2004
  #145
thecheat's Avatar
thecheat is an unknown quantity at this point
just waiting till I get a day I can make some calls and get something fabed. who has one from ebay? how wide is the body of the absorber?
Old Apr 30, 2004
  #146
cdmx's Avatar
heyy
why dont you buy mine?
Im getting rid of alot of stuff
Old May 5, 2004
  #147
a member here has a buddy that makes billet stuff
I have requested that he make brackets for the engine damper
http://www.7thgencivic.com/forums/sh...18#post2004118
Old May 12, 2004
  #148
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
and
something like this.
Old May 12, 2004
  #149
thecheat's Avatar
you guys think that the strut tower is thick enough to bolt into like that without wrecking it or causing it to deform? I'm just a little nervous about drilling into that to hang a bracket
Old May 12, 2004
  #150
djmota's Avatar
the strut tower is pretty thick and should handle a bracket with a decent sized base fine.
I am buying cdmx's dampner so i'll be trying to fit this as well.
