Notices
Brakes help
Old Oct 16, 2022
Blueeg's Avatar
Blueeg is an unknown quantity at this point
Brakes help
95 civic CX hatch I have replaced brake booster, master cylinder, bleed all the lines million times.. brakes get hard with car off as soon as you start car straight to floor, I do have barely any brakes running out of ideas what it could be
Old Oct 16, 2022
Re: Brakes help
bleeding works for soft pedal, not hard pedal
have you checked lines, calipers, etc?
are some corners even wearing?
Old Oct 16, 2022
JHB's Avatar
JHB
JHB is an unknown quantity at this point
Re: Brakes help
Just had the same problem with a VW Passat. Replaced the master cylinder. Then blead the abs module again.
Old Oct 16, 2022
FRSam's Avatar
Click Here
Re: Brakes help
This car doesn't have ABS, and given the master cylinder was just replaced, this is unlikely.
Old Oct 17, 2022
Colin42's Avatar
Re: Brakes help
Could be a bad master/booster even with new parts
Old Oct 17, 2022
Blueeg's Avatar
Re: Brakes help
I did buy master cylinder off of Amazon, I have a parts hatch I took that master cylinder tried it, it didn't change anything, so I bought the new one off Amazon. I'll have to change rear brake drum parts to see if it fixes anything..
Old Oct 17, 2022
FRSam's Avatar
Click Here
Re: Brakes help
What kind of hose are you using when bleeding? Does it go far enough out so you can see what the fluid looks like? Given the current scenario, the only reasonable assumption that I can come to is that there's still air in the lines.
Old Oct 17, 2022
Blueeg's Avatar
Re: Brakes help
I used cheap harbor freight bleeding tool, so it filled a cup up with fluid which was black, took probably 3 fills of the cup on each wheel to get ran fluid.. then I had somebody push pedal 3 times hold and did it that way on all corners.. used 3 big bottles of brake fluid
Rrac72
Brakes
Jan 25, 2022 01:27 AM
chazual
Aug 18, 2011 04:29 PM
deetzkid
Wheels and Tires
May 22, 2011 10:09 AM
koisser6284
Jun 23, 2010 11:40 PM
