Won't go into gear
Old Jul 21, 2022
Tylerreber's Avatar
Tylerreber is an unknown quantity at this point
Won't go into gear
So after swapping my motor from my automatic 95 civic to my new Honda Civic 5 speed I start to hear a whining/growling sound coming from the tranny so I proceeded to do a tranny oil check/change and come to find out not even barely a fluid oz came out so there for the mechanic that swapped the motor didn't do his job so after I put 2 quarts of oil in it and let it off the jack stands and turned it on and let it run for a minute the noice what i was hearing sounded like it was starting to quiet up so I started lightly reving the engine from under the hood little at a time to help the tranny warm up and fluids to work there way thru it and all the sudden after the 3-4 rev it jerked forward and stalled and now it won't go into any gear. I'm really really hoping that i don't have to replace the tranny now
Old Jul 21, 2022
FRSam's Avatar
Click Here
Re: Won't go into gear
I'm guessing it goes into gear but doesn't go anywhere? Like it has a bunch of neutrals?
Check your axles. They link to an intermediate shaft so if one pops out, the transmission won't engage.
Old Jul 21, 2022
Tylerreber's Avatar
Whenever it jerked forward I'm thinking it went into 1st and now won't come out and the shifter reads it's in neutral
Old Jul 22, 2022
BrotatoChip's Avatar
Super Moderator
Shifter was not in gear when this happened? Check your shifter cables. You can also remove them from the transmission and see if it will shift normally from there. If not, transmission is coming out.
civichxtreme
Jan 22, 2006 10:14 PM
bangemsmurf
Dec 12, 2005 06:57 PM
vicLX
Sep 25, 2004 11:11 AM
XtremeJM
South Cali
May 8, 2004 11:28 AM
SuzukaBlueCivic
Oct 3, 2002 01:40 AM
