MAP sensor engine when driving to puddles.
Old Feb 21, 2022
br94civic's Avatar
br94civic is an unknown quantity at this point
Smile MAP sensor engine when driving to puddles.
1994 Honda civic DX. the engine was swapped. The engine is a 1995 1.5L D15B.
I've had this issue for years now. Car stalls when driving through puddles of water. I get a MAP sensor engine code. OBD showed 20psi on the MAP.
Old Feb 21, 2022
Colin42's Avatar
Re: MAP sensor engine when driving to puddles.
Check the connector and the wiring. Either it's getting wet or you're sucking in water. Do you have an aftermarket intake?
Old Feb 22, 2022
br94civic's Avatar
i do not have an aftermarket intake. When I get the engine code my OBD shows 20psi. If I start up the car and push the gas for a minute or two the PSI goes back down to normal and I can clear the engine code.
I'll check the wiring.
Does water usually get in from below the air filter?
NinjaGirl54
Feb 2, 2023 10:28 AM
Thaik
Jan 19, 2013 06:11 PM
vincent.hkchua
Apr 12, 2011 11:36 PM
chris694205
Jun 14, 2009 02:32 PM
adamzeppelin
May 13, 2006 02:43 PM
