obd 1 engine into obd2 car
Old Jun 9, 2009
chris694205's Avatar
chris694205 is an unknown quantity at this point
hello... i have a 97 civic and it has an obd1 engine in it.... dont ask... anyhow i keep gettin the csf sensor no signal code coming up and i think it is because the obd 1 engine doesnt have it???? does anyone know how i could bypass this or something to get the check engine light off???
Old Jun 12, 2009
sql_civic's Avatar
Re: obd 1 engine into obd2 car
Yes you are correct there is no CSF in an ODB1 engine. There is a bypass but sorry I don;t have a link for you.
Old Jun 12, 2009
anyone???? it also just started idling like crazy and threw a p1337 code which i believe to be the idle air control?? anyone know what to look for or do i just replace the sensor?
Old Jun 13, 2009
sql_civic's Avatar
P1337 is NOT the IACV.
Google it, man!
Diagnostic Trouble Code (DTC) P1337: No signal in the Crankshaft Speed Fluctuation (CKF) sensor circuit.
Description
The diagnostic system has a pulser rotor on the crankshaft and a pulse pick-up sensor on the engine block. The ECM/PCM monitors the crankshaft speed fluctuation based on the CKF sensor signal, and judges that an engine misfire occurred if the fluctuation goes beyond a predetermined limit.
OK, I took 3 seconds and googled "CKP bypass trick". Here's your link:
http://rywire.com/store/faqdesk_info...49745061c2e15e
Old Jun 14, 2009
sorry man it had that code to... but it also has a p1509 which i believe is the iac
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
kevin99ek
Apr 23, 2015 09:32 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Unstoppable
Nov 7, 2001 11:50 PM
