Starting Issue after timebelt/waterpump.
Old Feb 23, 2019
OFWGKTA_Joel's Avatar
OFWGKTA_Joel is an unknown quantity at this point
So I did the timing belt/water pump on my 1998 Civic Lx. Timing marks are all on the spot so far. No leaks. Appears that everything is connected as far as sensors. When I try to crank it, it starts sometimes but very shortly and then shuts off. But most of the time it takes multiple times for it to start. During those attempts the speedo sometimes jumps and hear something clicking from my glove compartment. Any ideas would help. I'm beat so far..
Old Feb 24, 2019
Wankenstein's Avatar
Re: Starting Issue after timebelt/waterpump.
Possibly weak main relay?
Old Feb 24, 2019
That sounds alot like the issue and it's right where I hear it coming from. I'll look into it and let you know what happens after. Thanks for the tip.
Old Feb 24, 2019
Installed the new relay, the flickering stopped and the clicking did too. But still wont turn over. Any other leads?
Old Feb 24, 2019
Colin42's Avatar
Ignition switch?
give the starter a smack?
can you bump start it?
Old Feb 24, 2019
I figured it out, the ground connected to where the thermostat goes wasnt grounded properly . Started right up. Thanks for all the help!
CivicFried
Air Conditioning
Aug 10, 2019 11:48 AM
Wild Cranker
427
Jan 28, 2016 06:49 PM
petrie
Apr 23, 2014 09:53 PM
nitro169
Dec 8, 2013 06:08 PM
WillSerenity
Aug 19, 2013 06:45 PM
