2002 honda civic ex issue please help
Old Apr 19, 2014
petrie's Avatar
petrie is an unknown quantity at this point
I am new to this site. I own a 2002 Honda civic ex I was driving it to work the other day when I got a bad hissing sound it was pretty loud, lost power going up a smaller hill, I thought it was a exhaust leak if I let off the throttle it would stop and only make the loud hissing noise when I stepped on the throttle, when I took it out of gear the car died and have not been able to start it again. it had a p0420 code and a p0131 code on it. things I have tried already I replaced the fuel pump, took the cat off, and checked for stark, nothing fixed this yet, I am going to check compression today to see if the timing is good, has anyone had this issue before? the engine is the SOCH 1.7 thanks!!!
Old Apr 19, 2014
Re: 2002 honda civic ex issue please help
Even if you have compression, you should still inspect the physical cam/crank timing marks to make sure it didn't jump time. The computer can and will shut it down if it jumps time past a certain number of teeth.
Old Apr 21, 2014
petrie's Avatar
Checked compression good compression but noticed after I cranked the engine and pulled the plugs they were dry no fuel past the injectors any idea where the main relay or fuel injector relay is?? Thanks for the post
Old Apr 21, 2014
Does the check engine light come on when you turn the key on? (Yes- Main relay #1 is ok.)
Can you hear the fuel pump prime for 2 seconds when you turn the key on? Gotta have fan and radio turned off, the fuel pumps are real quiet. (Yes-Main relay #2/Pump relay is ok.)
If yes to both of those, I might pull the upper timing cover and inspect cam/crank timing.
Old Apr 22, 2014
petrie's Avatar
Okay yes the fuel pump comes out and I am checking the timing today thanks for the help!
Old Apr 23, 2014
petrie's Avatar
How would I check the timing just pulling the upper cover?
Old Apr 23, 2014
I'd say to read up on how to replace a timing belt on one of these cars 01-05 with a 1.7 engine, pay particular attention to the timing belt installation steps and timing mark identification and alignment. Once you understand the hows and whys of the job, you might better understand how to inspect yours.
There's some DIY threads on it here in these forums, do a search?
A good service manual would be of great help if you need better information.
HTH
alexkharden
Apr 23, 2015 07:13 PM
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
vino
Nov 3, 2001 11:08 PM
