Manual Shifter out of alignment
Old Jan 26, 2019
90sguy's Avatar
90sguy is an unknown quantity at this point
Question Manual Shifter out of alignment
Hey guys,
My 97 (5spd) shifter is out of alignment. What I mean is that gears 1,3,5 are pushed way forward, neutral is slightly forward, and 2,4,R are where neutral should be. My transmission feels good, clutch is good, gears shift and stay, but just the shifter itself is out of line, does anyone know why this may be?
Is it possible that the cable is just overly tight and will become loose with time?
Thanks
Old Jan 26, 2019
Re: Manual Shifter out of alignment
If you crawl underneath and look at the shifter mechanisms, you should not find any cable.
Could just be in need of some bushing replacements?
Old Jan 26, 2019
mac25's Avatar
Dr Krieger of Modification
Also check the torque mounts (the engine mounts that keep the engine/transmission from rotating).
If these go the engine can rotate a good half inch forward or backward.
Old Jan 26, 2019
90sguy's Avatar
I just got a new engine mount for my civic, so it's probably part of the reason why it's forward now.
My car was serviced recently, so I assume it's the engine mount since nothing needed to be replaced.
Thanks guys
Old Jan 26, 2019
mac25's Avatar
If only one was replaced that's probably why it's out of wack, replace the other three, as needed.
brkshr
Aug 3, 2011 03:03 PM
jtreat
Apr 16, 2010 09:20 AM
Zeferint
Aug 16, 2009 08:37 PM
chawski
Aug 19, 2007 11:32 PM
turboengnr
Dec 12, 2004 06:13 PM
