00' Civic - loose shifter
Old Aug 11, 2009
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Hey all
Juist bought a 00' Civic in early Feb with about 103k miles with two previous owners. The car itself runs great, but even in gear, I can wiggle the shifter at least an inch in either direction. I had my older brother shift the car with it off and I found a cable underneath the car that moved everytime the car shifted. What is this cable called, and is it the answer to my problem? I would like to try and tighten up this wiggle room.
Old Aug 13, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
Re: 00' Civic - loose shifter
Hello,
Your car does not have a cable actuated shifter (unless it's an automatic). For manual shifters, sometimes the linkage bushings can rot or become damaged in some way. Replace those inexpensive items and you will be much happier.
Old Aug 13, 2009
Zeferint's Avatar
Autocross Padawan
Originally Posted by ScottDR
Hello,
Gotcha. Is it easy to access these bushings? Where can I find an exploded view of my car's transmission? I assume I can access these bushings by simply taking off the boot, it would seem improbable that I would have to drop out the transmission in my car to get to them.
Old Aug 16, 2009
ScottDR's Avatar
The aforementioned bushings are at the shifter, not at the transmission. I'd look at www.hondaautomotiveparts.com or www.hondapartsdeals.com for a view of the shifter and it's pieces. They are accessible from under the car.
thesushiboy
Apr 12, 2015 02:54 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
vistec
Nov 9, 2001 05:12 PM
CIVICINJEN
Nov 6, 2001 01:30 PM
GreenVenom
Nov 6, 2001 12:47 PM
