Sponsored by:
Sponsored by: CARiD
Home built short shifter a success
Old Dec 10, 2004
turboengnr's Avatar
DONT PANIC
Exclamation Home built short shifter a success
Well, after whining and complaining about spending $45 on a short shifter adaptor, i decided to build my own. With a band saw, drill press, and a sheet of aluminum, i took about an hour out of my day and built an adaptor.
It was quite a bit easier than i thought. I made it so it slipped over the stock shifter cable mount, but held right against the shifter itself as not to move. Then i cut out a piece to bolt to the adaptor to pinch the stock bracket between the two, thus keeping the shifter from ever moving. I used an 8mm bolt and 2 nuts (run together so they wont come lose) to hold the shift cable. And i put the cable forward enough so that the shifter sits a little farther back than stock, so i dont have to lean forward to put it into 1st, 3rd, and 5th.
But the adaptor worked perfect. It shortened the throw noticably, and the shifter feels precise and smooth. Just like it was brand new.
If i feel like taking the console apart again, i may take some pictures and maybe do some sort of DIY on it for you do it yourselfers out there. Basically, this took me about 1 hour and about $1.50 in materials. Screw those huge companies!
Old Dec 10, 2004
Shifter's Avatar
Shifter is an unknown quantity at this point
Great job! It just goes to show you what a bit of patience and a few bucks will get you. If you can create a procedure, complete with plenty of pics, I'm sure many will appreciate it.
Old Dec 10, 2004
MrDibbs19's Avatar
MrDibbs19 is an unknown quantity at this point
how much of a difference in the throw do you think you made??? good job though!!!
Old Dec 10, 2004
mexinaction's Avatar
good job, post a diy fo sho
Old Dec 10, 2004
PacSmalls's Avatar
PacSmalls is an unknown quantity at this point
i already have a short shifter but itd be sweet to see a DIY on this! you'd get a ton of rep points
Old Dec 12, 2004
turboengnr's Avatar
DONT PANIC
ill make up a little template and what not for you guys to print out and trace on some aluminum. If you have a drill and some way of cutting aluminum sheets (<1/8" thick) then you can make this.
It made a difference. Not like "oh my god, i dont even have to move it to shift", but the throw is shorter and feels stiffer.
I will make the template and DIY stuff this week. Im outta work for a bit while qualifying for this job, so i will have some time on my hands.
Ccoop87
Jul 9, 2015 03:26 PM
robbie374
Jul 7, 2015 02:56 AM
TuRtLE714
Jan 5, 2002 09:14 PM
Jodster
Dec 29, 2001 09:00 PM
CIVICINJEN
Nov 6, 2001 01:30 PM
