Windshield Spray Nozzle Cleaning
Old Aug 4, 2018
Wankenstein's Avatar
'95 Civic EX Coupe-de-Dong.
Presently only one (out of four) of the spray nozzles are working on me ride. On one of my past Civic's I tried using a sewing needle and cleaning out the nozzles but that just made things worse. Best way to clean nozzles? Possibly the pump is weak or needs cleaning?
Old Aug 4, 2018
Colin42's Avatar
Re: Windshield Spray Nozzle Cleaning
Soak it in rubbing alcohol?
Old Aug 4, 2018
That would most likely work. I found this video that may work too:
Many years ago I owned a BMW 528E (straight 6 cylinder) and it's one of my favorites. Overall not a fan of BMW though when it comes to repairs.
Old Aug 4, 2018
Needle or pin can be too fat.
I frequently use "tag wire" to poke them out, maybe bread tie wire is fine enough to do it too.
I also use wire size, and/or jet drill bits
follow up with a shot of air from a blowgun in both directions
Old Aug 4, 2018
Originally Posted by ezone
Needle or pin can be too fat.I frequently use "tag wire" to poke them out, maybe bread tie wire is fine enough to do it too.I also use wire size, and/or jet drill bits follow up with a shot of air from a blowgun in both directions
Thanks Ezone. I have a spool of wire that's very close to tag-wire size.. will give it a go and report back.
Old Aug 8, 2018
Removed nozzles from hood, blew 100 psi compressed air through them in both direction, re-installed and now working well. Thanks for all the replies.
raj_very
Buy, Sell, & Trade - Archive
Jun 11, 2010 07:43 PM
Imtheconvict
Dec 18, 2005 02:47 PM
booba5185
Nov 15, 2005 12:46 AM
streetglower
Jun 29, 2005 08:15 PM
OniChi
Mar 31, 2004 12:36 AM
