90 civic dx 1.5 running rough
Old May 21, 2014
90efhatchsyrny's Avatar
90efhatchsyrny is an unknown quantity at this point
Hi, I'm new to this site..I bught my ofirst civic recently and I've noticed a couple things. The car seems like it has a skip in it. I know alot about cars and I know its not a misfire. I changed the oil and checked the plugs and they are fine. Seems like it may be running Rick cause I smell fuel once in a while.when I shut it off and start it a few minutes later it starts seems like its about to stall t hen Idles high then drops to onormal don't knohw too much abut tcars
Old Jun 29, 2014
civicenter's Avatar
civicenter is an unknown quantity at this point
Re: 90 civic dx 1.5 running rough
Check or replace plug wires: Use NGK
Replace the plugs: using NON platinum plugs. NGK preferred
Cap and rotor
Check Timing
Next culprit, Distributor, but don't touch it until all the above have been checked and or replaced.
Old Jun 29, 2014
civicenter's Avatar
Short story: I had a similar hiccup once and I ended up removing the distributor to see if I could see anything noticeable. To my surprise I saw that the screw/bolt that holds the rotor in place fell off. This was causing the rotor to spin on the shaft. Never had seen this happen before. Make sure that little bolt/screw is on tight..good luck
mattdoc
Mar 14, 2017 12:10 PM
dragonsblood
Apr 27, 2015 12:28 PM
djdefcon
17
Apr 6, 2005 11:52 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
EvilTwin
Nov 8, 2001 12:17 PM
