93 civic dx feals alittle under powered!! help
Hi.. I just bought a 93 DC with the 4 speed automatic and it feels alittle slow on a half to full throttle take off and this is even from coming off a exit ramp onto interstate. And u get up to 70mph and it just seems hard to go any faster with foot to the floor even .. any help is greatly appreciated!!!
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Re: 93 civic dx feals alittle under powered!! help
Has it had any work done to it recently? Is it only slow at 70? could be timing..Im sorta shooting in the dark atm...Check engine light on?
No check engine lights of any sort .. and actually it will get up to like 60 pretty decent for just a 1.5 non v-tec. But it was turboed. By last own but he removed everything for the Turbo setup except the gauges .. he left those in the car. But as far as motor work he didn't mention much about modification. Inside the motor. Except thicker gaskets to boosting. The car has full 2" exhaust with headers. And that's regular headers not the headers from Turbo setup which u would kno.by this point .. thank u for any help
Does it still have a cat?
If it hasn't been removed, I might start with vacuum drop and backpressure tests.
No I haven't done spark plugs and wires and oil Change plus air filter .. I just got car lastnight but guy claims he did all that last month but I just checked the oil and it's black so I am guessing he is full of BS .. and also it's a d15b7. What's the hp on this motor stock?
There is no cat in the exhaust system .. and I bought the car because he was told the roof above windshield is dented in from hood flying open and smashing windshield .. I kno have a friend that knows the guy that had it before the guy I bought it from and he is the one who had this car turboed and trying to reach him to get more info on this car.
Find out what you can, the more info you get the better..and you might want to get a cat..(not the animal..LOL)
advance the spark a little by turning distributor and put 91 octane in it with NGK iridium spark plugs. you should have plenty of gusto then.
^ sorry, for now that is trying to mask the issues.
he needs to solve the real issue, but needs to do at the least remove some parts and see if they need replacement. look at the oil color comment for example.
Well guys sorry I didn't get back sooner .. but swapped out for new omni 7mm plug wires and ngk plugs and runs way better and alot more snap and go to it!! Now next is she is burning alot more gas and yes I always run 91 octane in my vehicles. And I filled tank full and drove 65 miles and used nearly 1/2 a tank? And no there is no fuel pressure regulator or any else for the fuel delivery unless ot like the O2. Senser? I have cold air intake but I kno that doesn't change the way your car should burn that much fuel that fast. And I got a friend that has been helping me and he is gonna do the oil change for me sinc I just went through a shoulder surgery 2 weeks ago but ya it's black as a asphalt!!
Last edited by Rockys_93civic; Dec 30, 2011 at 07:12 AM. Reason: forgot to add more info! sorry
Jonnie.
Jan 13, 2019 11:21 AM
moorebl
Aug 29, 2015 08:39 PM
SSMatey
Apr 13, 2015 06:09 PM
