Can you start with the main relay jumped ?
Old Dec 11, 2011
CdXa's Avatar
CdXa is an unknown quantity at this point
i'd like to know is if it is possible to start a healthy running 5 gen. Civic with the main relay pulled and a jumper wire in the main relay plug.
why ? well....
When i jump the main relay plug, i hear the fuel pump kick on, but the car does not start despite having spark ( weak, but enough to fire )
This would point to the fuel injectors as a possible problem, but if this were the case then the main relay should kick the fuel pump on, but it's dead silent and without current to the pump ( tested at the pump )
I tested the main relay for continuity and it checks out fine. I have a brand new one ( perhaps 150 miles ) that has the same symptoms.
I checked the ignition for continuity today, and it's fine as well. :hothead:
I started a thread on it here, but haven't had any replies.
https://www.civicforums.com/forums/2...its-humid.html
Thanks
Old Dec 11, 2011
Re: Can you start with the main relay jumped ?
Only if you know what you are doing. The PGMFI main relay is a dual relay.
Get a wiring diagram and look.
One set of contacts (jumper terminals 5 to 4) powers the fuel pump,
the other set (jumper terminals 6 to 7) powers the ECM and some other things, like the injectors and the O2 heater.
It can't run without both of these powered up at the same time.
Old Dec 16, 2011
MrDobin's Avatar
MrDobin is an unknown quantity at this point
I may be saying the obvious. THough as a college student I can understand budgets.
Why not just replace the thing?
I have re-soldered the points on my for good measure but i wouldnt bother jumping it.
Jonnie.
Jan 13, 2019 11:21 AM
Wild Cranker
427
Jan 28, 2016 06:49 PM
jetcare101
May 8, 2015 01:33 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
