94 Honda Civic EX cranks but quickly dies
Old Jun 25, 2011
oquela's Avatar
oquela is an unknown quantity at this point
I have a problem that I've narrowed down to a couple of things. Here are the symptoms.
1) car cranks, starts, then quickly dies
2) I click to II on ignition switch...no lights, no priming of fuel pump sound
3) start the car on ignition switch, (position III) but it immediately turns off.
4) If I play/jiggle key between III and II without cranking, I get the sound of fuel pump priming, and the CEL turns on, then off after a second or two. It started about a month ago, especially in the mornings, but when I restarted it, it would quickly stay on.
I think it may be the following:
1)bad fuel pump
2)bad ignition switch
3)bad main relay.
am I on the right track? What else should I check? Thanks!
Old Jun 26, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
Re: 94 Honda Civic EX cranks but quickly dies
for the motor problem then i would try to check these things out , it could be a loose connection at the distributor or a vacuum leak at the gasket between the intake and throttle body or insufficient fuel reaching the fuel injectors but if u have to jingle the keys for the fuel pump to prime then i definatley think that it would be the switch
Old Jun 27, 2011
oquela's Avatar
OK, have one more thing I found out. If i keep the key pressed forward just enough, the car stays on, so I'm guessing it's the ignition switch.
One more question....do I have to change out the whole thing, including a new key, or is it just the back portion with the wiring harness?
thanks!
Old Jun 28, 2011
turbo_coupe_EJ1
you could change the part in the back but if it was me i would just change the whole thing cause it sounds like the switch itself
Old Jul 24, 2019
fgb000's Avatar
fgb000 is an unknown quantity at this point
Hi there friends.
I'm having the same problem with this ignition switch.
The phase II when I turn the key over is not working properly,
The thing is that when I fire it up on phase I, the thing will die after releasing the key back to phase II on the ignition switch.
I've already changed it once, andit didn't last 2 years.
Is there a way to repair the ignition switch white plastic part for good?
That white round plastic and of the ignition switch harness.
Will a 96/00 ignition switch harness fit for my 95?
Thanks.
Old Jul 29, 2019
fgb000's Avatar
Civic 92/95 to 96/00 ignition switch harnesses are they interchangeable?
Could I use the same harness for the ignition switch on civics 92/00 ?
THANKS
TJwheels
Apr 30, 2016 04:07 PM
CanadianAccord1
Jan 6, 2016 04:43 PM
Blondie40
Nov 19, 2010 09:09 PM
cappy
Jan 30, 2009 10:12 PM
lavared
Oct 28, 2004 01:24 AM
