Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
D16Y7 compression problem?
Old May 11, 2021
Ohio-D16's Avatar
Ohio-D16 is an unknown quantity at this point
So my Civic was once my dad's daily car and it eventually started to struggle moving under its own power. So his response was to compression the cylinders and the cylinders were (in order) 80, 90, 30, 105. Now I am not a trained mechanic and I have no idea what the compression test tells about the engine, my dad's remedy is to take the head off and have it worked on ( I cant remember what exactly he said) but I feel like there's more wrong. Anyone got any advice? I'm a wanna be mechanic and work on cars but I have no idea where to start. I also don't know if this is the right place to ask this, I'm still new to this and haven't had time to look around.
Old May 11, 2021
FRSam's Avatar
Click Here
Re: D16Y7 compression problem?
There are a variety of reasons that compression could be bad. My first guess would be bad piston rings because the rest of the numbers aren’t great either. Could also be something like leaky intake or exhaust valves. Dry adding a tablespoon of oil to each cylinder and see if that makes a difference. If it does, it means your piston rings are shot.
What’s the mileage on it?
Old May 11, 2021
Ohio-D16's Avatar
It has 260,230 miles on it. plus its been sitting for a few years
Old May 11, 2021
probably piston/cylinders wore out and needs a full rebuild
(new larger pistons, bore cylinders, etc.)
Old May 12, 2021
Colin42's Avatar
Potentially much easier and cheaper to put in a used engine for a few hundred dollars
Bulzi73
Mar 1, 2020 08:52 PM
Nov 22, 2016 07:27 AM
JNVA17
May 2, 2013 02:54 PM
Uncle X
Jun 4, 2012 06:58 PM
MadWheel
Engine Swaps
17
Aug 12, 2004 12:14 AM
