Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
300 whp Civic build- Help
Old Dec 7, 2015
JDMnoob's Avatar
JDMnoob is an unknown quantity at this point
Hey guys. So currently I have a '96 Civic with a D16y7 non-vtec and auto tranny.
I'm wanting to make about 300whp (going from roughly 106 lol.) I'm just curious, what're some of the best ways (swaps, F/I&Swap, internal work etc..) to go about reaching this number?
Like my name says, I'm new to this so any information will help
Thanks in advance.
Old Dec 7, 2015
Mad Dog Tannen's Avatar
Re: 300 whp Civic build- Help
Whatever you get, you would have to do some head work for an all engine build, or you will have to go forced induction/nitrous. An engine swap would be necessary too. Neither of these are noob level mechanics.
Old Dec 7, 2015
Miss EJ6's Avatar
BPL Namdata
Miss EJ6 has a spectacular aura aboutMiss EJ6 has a spectacular aura aboutMiss EJ6 has a spectacular aura about
you got a lot of different setup and choices to choose from. you need to sit down and really think about in more details on what your looking for other then wanting to have 300hp under your hood. like mad dog said N/A setup needs lots of head work to make those numbers. on a FI setup is pretty easy to do but you'll need to be on point with tune and fuel system
Old Dec 11, 2015
Wankenstein's Avatar
Replace your automatic with a manual transmission.
Old Dec 11, 2015
Haha. That will make it more fun to drive, and better gas mileage too. It will still be gutless.
Old Dec 12, 2015
OP wants 300hp on an automatic transmission.. those stock auto trans. can barely handle the stock SOHC grocery getter. lol. Hardshifts anyone?
Old Dec 12, 2015
Why wouldn't an automatic take 300hp? I am sure there are plenty out there that could.
Most drag race cars are automatics!
Also it sounded like you where suggesting that doing a manual conversion, was all that is necessary.
Old Dec 12, 2015
we just have seem two more with failed auto trans with around 100k miles, so they are fragile, even at stock power. some seen to be lucky and get far more than that, but the percentage is far from negligible, unfortunately.
mot a 6th gen, this is for 7th (which are worse, I will give you that)
https://www.civicforums.com/forums/7...to-thread.html
auto trans info
Old Dec 12, 2015
auto trans info
So don't use the stock one. Example: if you are swapping a J series engine the auto trans should be able to take 300hp. No need for a manual.
Old Dec 12, 2015
Don't think any j series packs 300 hp in stock form either... or if it fits...
Old Dec 13, 2015
mac25's Avatar
Dr Krieger of Modification
the j37's are nearly all 300hp stock ...11.2:1 compression stock =D.
Old Dec 13, 2015
mac25's Avatar
...and there is talk that the new nsx will use a dohc j37/eletro engine combo.
Old Dec 13, 2015
here, my reply to another thread. Don't go lightly into J-Swaps
Ah, I did google about J swaps, but did not see any 7th gen.
Also, it did seem that they are swapping the whole power train (not sure what is needed, engine/trans mounts, wiring harness, mounting points, hacking engine bay, modifying the half axles to fit the trans to the suspension, etc)
PS: instead of asking, I highly recommend reading the stickies in the top, also google - there's a 14 page thread in another forums, BTW...
after reading all, then you start making more informed questions, not random ones. Honestly. If you are in the internet, it's a click away - much easier than nactually doing it. If you wait us to mouth feed you, it's not likely you will end up finishing the job.
Old Dec 13, 2015
It fits, many J engines make around 250 and can handle 300. Autos are often faster on the drag strip, so it really depends on what he wants to do. I would get a manual for the twisties though.
fatih717171
Jul 25, 2016 06:22 PM
alinaray
18
Aug 24, 2015 01:04 PM
hayden55
Jul 8, 2015 11:38 PM
Mike_47
Transmission
Jul 8, 2015 02:42 PM
onelifetolive
Bolt-on Engine Performance
Nov 10, 2001 10:58 AM
