Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
B18c-r struggling occasionally only at low rpms
Old Sep 29, 2010
bsm123's Avatar
bsm123 is an unknown quantity at this point
hi, over the past few days, whenever i press the accelerator slightly more when im on a higher gear and low rpms, my engine struggles and is sluggish, not wanting to move and after about 3 or 4 seconds suddenly kicks in and is fine. usually around 2-3k rpm is sluggish. ive read some other posts but the thing is mine is only OCCASIONALLY and sometimes its fine.
also i found out yesterday that one of my gaskets along my exhaust was leaking and replaced that. the sluggishness seemed to be better after that but then it happened again once or twice much later during the day.
one more thing, i recently went for a dyno tune, except that during that time, my gasket might have already been leaking and maybe the proper readings werent being sent to the air/fuel sensor which they plug into the exhaust. does this mean after i replaced the gasket i now have to go for a re-tune and that the settings now are not matching my engine as it should?
thanks.
Old Mar 29, 2011
99sicivic's Avatar
Josh
99sicivic can only hope to improve
Re: B18c-r struggling occasionally only at low rpms
Idle air control clogged up ? or crank sensor when its raining if wires are showing it might short out and come back in at high rpms just guessing tho even fuel pump could be the problem but i dont see it clearin back up at high rpms lol
Old Mar 29, 2011
have been a few months already on this one too - old thread. I gues there were not many replies because this have nothing to do with swaps and forced inductions either.
Old Mar 29, 2011
99sicivic's Avatar
Josh
Never even notice the date at work readin post lol bored what was it if you dont mind me asking ??
Old Mar 29, 2011
jus' let the old boys to rest
Old Mar 29, 2011
99sicivic's Avatar
Josh
lol k
Old Mar 29, 2011
some of the old ones is OK to bump, since they are funny or similar, but this one is more serious, so not worth bringing back up after so long time passed - it was posted on the wrong section from start
mrohitredd
May 30, 2015 06:51 PM
mrohitredd
18
May 14, 2015 07:35 PM
dooner24
Apr 14, 2015 07:51 PM
Aznnp77
Dec 13, 2001 04:03 PM
