Suspension
Old Feb 28, 2010
jwhicker's Avatar
jwhicker is an unknown quantity at this point
Suspension
I am new to this so bear with me. I recently put 16" wheels and tires on my 2000 civic ex coupe, and now on sharp turns or large bumps the wheels hit the wheel wells. What is the most cost effective way to fix this problem? Thanks
Old Mar 1, 2010
civic0918's Avatar
civic0918 is an unknown quantity at this point
Re: Suspension
Well i would lower 2inches and get strut braces front and back.Then you wont have any body roll at all solving the problem.
Old Mar 1, 2010
ronaldo9's Avatar
Re: Suspension
Roll the fenders or if u have coilovers raise the car up some to allow more travel.
Old Mar 1, 2010
2005civiclx's Avatar
2005civiclx is a jewel in the rough2005civiclx is a jewel in the rough2005civiclx is a jewel in the rough
Re: Suspension
your hitting the wheel wells on 16"s. sounds like a suspension problem to me. my brother is lowered on 17" in his 6th gen and its almost no wheel gap and he doesnt hit the wheel wells. and im lowered on 17" about the same amount on my civic and i dont hit the wheel wells.
maybe getting some coilovers or some lowering springs and shocks would help that out. Is your car really bouncy when you push down on it?
Old Mar 2, 2010
jwhicker's Avatar
Re: Suspension
Thanks for the advice. It is not super bouncy, not more than any normal car. I did not get the right size tire, which is causing the rubbing. My tire has a larger sidewall than I was hoping for. So in conclusion the most cost effective way would be rolling the fenders? Where is a good place to get that done?
Old Mar 3, 2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
Re: Suspension
You should get different tires so that the total diameter of the wheel is not greater than the total diameter of the wheel with factory rims and tires.
No point to getting bigger rims if you're going to get thicker tires as well... it also screws with your speedometer and odometer.
Old Mar 11, 2010
jwhicker's Avatar
Re: Suspension
Thanks for the help. I am just going to get some smaller tires.
Old Mar 13, 2010
nehaasen21's Avatar
nehaasen21 is an unknown quantity at this point
hi
Tedverseti
Apr 23, 2020 01:45 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
