Blowing fuses
Old Jun 15, 2018
Stacyracing33's Avatar
Stacyracing33 is an unknown quantity at this point
Blowing fuses
Hey guys, my taillights was working just fine up until this week they blew a fuse, I put a new one in blew another fuse 2 days later, and now it' blowing them as soon as I turn them on. Anyone have a clue what might be causing it to short out all of a sudden brakelights just started acting up all so come on when u push the pedal let off and won' work the second time till about a min later need help asap
Old Jun 16, 2018
Wankenstein's Avatar
Re: Blowing fuses
Read this: https://honda-tech.com/forums/honda-...fuses-3079359/
The wiring or socket may be grounding out somewhere. Remove the bulb, inspect and clean (rust?) the socket. After cleaning spray some electronic contact cleaner and lube in the socket. Example of spray: De-Oxit:
Amazon Amazon
Radio Shack may still have there brand of contact cleaner and lube.
If not one of the above then a break in wiring somewhere that's grounding out.
Old Jun 16, 2018
Re: Blowing fuses
Found the problem, front passenger parking/turn signal socket wires are dry rotted and brittal and hot wire was rubbing the fender. I'll have to get a new socket
Old Jun 17, 2018
Re: Blowing fuses
Old Jun 17, 2018
Re: Blowing fuses
same cause as the halos you were having issues with.
go around looking for more wire issues?
dustysaw
Oct 24, 2010 04:43 PM
Hookums
Feb 3, 2010 04:31 PM
Sweeeeet
Feb 24, 2009 10:21 AM
diggaflip
Dec 20, 2007 06:56 AM
shmik1
Mar 3, 2006 06:00 PM
