No Dash cluster or Climate light
Old Jul 16, 2011
LoveHonda's Avatar
LoveHonda is an unknown quantity at this point
Everything works fine before, once I installed JVC cd player in the car with harness wiring, I followed every single same color wire and made sure everything was in order. The cd player works fine, but now the dash light and climate light don't work? All the fuses are fine, no blown fuse or anything. Headlight and everything works. I researched and found out that the yellow wire is not nessecary to connect together with other yellow wire. Am I doing anything wrong?
I will appreciate if someone explain me whats the deal with this? Thank you.
Old Jul 16, 2011
lazlong's Avatar
Re: No Dash cluster or Climate light
This happens a lot when you mess with something behind that panel. Check the wiring (not the radio wiring, the other wiring) for bad wires or loose/bad connections.
Old Jul 16, 2011
LoveHonda's Avatar
Can you tell me which is the other wire you are reffering me to? I am sorry is there any people here who had this issues?
Old Jul 16, 2011
lazlong's Avatar
Look, you pulled the panel, right? Then you would have seen the wires leading to the climate controls (if not dis-connected them for better access) and the harness at the back of the cavity going towards the gauges.
Pull the panel out some, turn the ignition ON, then wiggle the wires to see if anything happens.
Old Jul 18, 2011
LoveHonda's Avatar
Hi ,
I will try your option and see what happen.
Old Jul 18, 2011
lazlong's Avatar
Wow, looking at that last post of mine I think I was a little rude. Yeah, wiggle the wires and post back.
Old Jul 18, 2011
LoveHonda's Avatar
I dont think that helped, I think I messed up with the dimmer wire and yellow wire illumination or something? I guess I have to get a used clutcher and wiring harness.
HiImBrandon
Jun 1, 2015 07:34 AM
trellex
May 24, 2015 04:39 PM
jimmyfloyd
May 20, 2015 07:06 PM
Ma213802
May 18, 2015 07:01 AM
bahena08
Apr 11, 2015 05:09 PM
