trunk leak 2000
Old Jan 18, 2019
Jp7's Avatar
Jp7
Jp7 is an unknown quantity at this point
trunk leak 2000
can anyone inform me where the moonroof drains are for a 2000 civic ex 4 door sedan? i have a little water in the same spot near the front passengers feet, and also in the trunk after a car wash.
Old Jan 18, 2019
Colin42's Avatar
Re: passenger floor is wet
Trunk is probably tailight gaskets or the trunk seal
Old Jan 20, 2019
Jp7's Avatar
Jp7
I went through the car wash yesterday with the rear seats down. Shined a flashlight back there and the leak is coming from the deck-lid flange on the right hand side. When I got home, I opened the trunk and poured some water (just a little) on the space where the bodyside sheet meal is welded to the deck inner flange and package tray. The seam is leaking. should be easy to fix. I have some urethane based glue I will try and let you know.
Old Jan 30, 2019
Jp7's Avatar
Jp7
I fixed the leak in my trunk. There was a hole in the seam where the bodyside meets the decklid opening. Urethane sealer did the trick.
The other issue I have is water intrusion through the blower motor opening on the right side of the dash. This has only been a problem going through a local car wash. I was getting about a table-spoon of water dripping from the blower motor. I removed the cowl and replaced the foam strips that help manage water coming down the wind shield. This helped a little but I didn't completely solve it. From time to time I still get a little dripping from the blower motor. I am 100 percent certain the water is coming from here as you can see the 3 fasteners that hold the blower motor into the hvac housing are a little wet.
Here is what I planned to do next. I'm going to make a "rain hat" for over the opening. Really surprised the new foam didn't fix it.
eliems
Jan 19, 2010 12:55 PM
Beave728
Nov 21, 2008 12:10 PM
bakuretsu
Dec 1, 2004 03:56 PM
quwok
Oct 2, 2004 04:41 PM
exedotbat
Nov 10, 2003 12:41 PM
