Water Leaking Into Trunk
Old Nov 20, 2008
Beave728's Avatar
Beave728 can only hope to improve
Just about every time it rains really hard outside, I will get into my car later to smell a strong, stagnant odor. Come to find out, there is a leak directing water straight to my trunk where the spare is located. If anyone else has had this happen to them and know where the leak might be coming from please let me know. Thanks!
Old Nov 21, 2008
Re: Water Leaking Into Trunk
i had a huge leak problem. first start by removing the carpet pieces and cardboard. then next time it rains, sneak into the trunk from the back seat with flashlight and with the trunk closed, see if you can spot water coming from around the weather seal where the trunk lid meets the car body. if not, look at the sides and above. make sure there are no holes where the wheel wells are to the outside. if there is water dripping from the sides on top but you cant see where its coming from, you have my problem. it ended up being a worn seal on the plastic trim on the OUTSIDE of the rear door window. i pulled it off, and its actually held on by clips and there are holes in the body. what happened was water would leak in through there and travel a long ways to the trunk where it would drip down from the side and eventually to the spare tire area. i put some liquid rubber sealer on the clips and then pushed the trim back in. that was the last time it leaked any water.
Old Nov 21, 2008
Beave728's Avatar
Thank you so much for your advice! I did make an observation on one occasion that the cardboard lid above the spare did get saturated, and I guess from there it leaks into the spare tire area. So I guess that it's dripping from the top of the lid. But I just recently had a lot of body work done due to major hail damage, that of which included a complete replacement of the roof panel. It's all their fault
Old Nov 21, 2008
yeah body work caused mine to leak as well... if you can, take it back to the shop. it took me weeks to find the leak and fix it. i had a hole in the wheel well too and in the trunk seam at first.
Old Nov 21, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
In mine it was where they drilled too big a hole for the trunk pin for the alarm. Water was getting around it and corroded it.
Old Nov 21, 2008
they put a trunk pin? shouldve just wired it to the dome light or something. i dont have any pin for mine.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
Mercilus
Jun 7, 2015 10:00 PM
brian257
Jun 4, 2015 08:17 PM
Importracer
Nov 4, 2001 07:50 AM
