Transmission slip
Old Sep 5, 2018
Dudeguy19's Avatar
Dudeguy19 is an unknown quantity at this point
Transmission slip
New here,I just bought a 2000 auto SE for $400.,just wondering if the VSS being out can cause transmission slips.It seems to get confused and bouce off the rev limiter when trying to go into third.
Also has anyone had any luck with aftermarket IACV's? The car is revving up and down when not in gear,throwing codes for the iacv .Did not want to pay $180 for the oem part on a $400 car so found a aftermarket on Amazon for $40. Tried cleaning the current one with no luck.Thanks!
edit:to clarify,the speedo and odometer are both out,and the car threw a VSS code,part is on the way.
Old Sep 5, 2018
Re: Transmission slip
Should have checked the wiring first. But I guess you'll find out real soon.
Old Sep 5, 2018
Dudeguy19's Avatar
i checked the pigtail as far back as i could.Engine bay is kind of gross(it sat for 2 months after passing inspection,iacv made it idle funny,exhaust broke off and speedo/odo stopped working.Guy thought she was toast or close to it,hence why it was $400) didn't see any obvious tears/cuts.Contacts looked good too.
Old Sep 5, 2018
Ok good. Someone posted the other day, had pics of a connector and VSS that was so corroded that one pin was completely missing. Rotted away to nothing.
Old Sep 5, 2018
Dudeguy19's Avatar
oh no i always check that stuff before buying parts,learned the hard way lol..not much corrosion on this car(besides where the obvious damage is from a truck backing into it),i did see the cooling fans have been replaced and rewired with electrical tape though,scared to dig deeper .like i said,$400 car though..lucky it runs at all.
John Mrowka
Dec 29, 2015 05:24 PM
dragonsblood
Apr 27, 2015 12:28 PM
TJMike
Nov 18, 2012 06:57 PM
masonpaine
Jan 14, 2011 11:42 PM
marek91
Jun 1, 2010 08:25 AM
