speedo not working
Old Jan 12, 2011
masonpaine's Avatar
masonpaine is an unknown quantity at this point
speedo not working
Ok so my 2000 civic dx speedometer is not working at all. It's been like that since i bought it. i just replaced the vss. didn't help. checked fuse..it was good. I tried a different gauge cluster... same thing. so what am I missing now? the vss sensor connector had some corrosion on it, but i took apart and cleaned it up nice to where I couldn't see the corrosion be a problem.
Old Jan 12, 2011
lazlong's Avatar
Re: speedo not working
1. new cluster is bad
2. new VSS is bad
3. abraided/broken wire (probably the problem)
Find a wiring diagram and test for continuity (ohms) or get a service manual (it has step-by-step troubleshooting instructions). In the meantime, look for abraided/broken wires (especially around the VSS).
Old Jan 12, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
well if u have an obd2 reader
like this that hook up to ur laptop
u able to know if ur vss is bad or not or ur ecu is getting the speed readings
if it does then u have a bad cluster or wiring goign to it
Old Jan 12, 2011
another way check and see if ur meters for ur miles are working
Old Jan 12, 2011
masonpaine's Avatar
the mileage counter is not working
Old Jan 12, 2011
lazlong's Avatar
You still need a wiring diagram.
Old Jan 13, 2011
wiring for?
Old Jan 14, 2011
lazlong's Avatar
the speedo circuit
Old Jan 14, 2011
once u find out that the sensor is sending signal to the computer
alll u gota worrie about is ur cluster
Old Jan 14, 2011
lazlong's Avatar
Really! So the ECM/PCM just sends a wireless signal to the cluster, I think not. There has to be a wire to send a signal hence the wire diagram so you can rule out the wire before you get a new speedo. What if he goes through the trouble of getting ad installing a new speedo and it still doesn't work? I'll tell you, it's the wire. Checking a wire is far cheaper than buying a new speedo.
werdnahall
May 17, 2015 11:37 AM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
