Question about rear door window moulding.
I bought a new driver side rear window moulding to replace the old one that was leaving brown goo on the window. What is the best way to remove the old moulding?
Re: Question about rear door window moulding.
If it's the vertical piece pull back the door seal and look for a screw(s) that hold the trim on, start at the top as there may only be one. Once you have the screw(s) out, pull up/out on the trim piece.
If it's the horizontal piece then pry it off with a trim tool. Harbor Freight has a cheap set. Get the metal ones, not the plastic set. Be sure to put something soft like a rag between the tool and the paint.
timpan
May 18, 2015 07:06 AM
werdnahall
May 17, 2015 11:37 AM
