Fuel injector problem
Old Jun 17, 2018
Dylan29's Avatar
Dylan29 is an unknown quantity at this point
Hello all
I just recently replaced my fuel injectors on my D16Y8 with OEM reman injectors from eBay. When I installed them I soaked the seals in gas. Now when I turn the car on the engine wants to bog down but when I give it some gas it starts to idle around 800 RPMs consistently and ad I'm driving I noticed a huge decrease in power and I also noticed a hint of gas smell inside the car. So I tried to both reset the ECU and do a idle relearn on the throttle body. I am still having the same issue after the fact and I just got two error codes P0171 and p0170. Could it be that I just have bad new injectors?
Old Jun 17, 2018
Wankenstein's Avatar
Re: Fuel injector problem
Why did you soak the seals in gas? I put a light coat of synthetic grease on the O-ring seal to help them slide in easier to avoid damaging them during installation. They seller may have sold you faulty injectors...contact him/her and let them know about the issue.
Old Jun 17, 2018
Dylan29's Avatar
I was watching a Scotty Kilmer video on YouTube of him installing injectors and he said to soak the Rings in gas.was thst bad? And I have a lifetime warranty on the injectors
Old Jun 17, 2018
The seals I believe are made butyl rubber and have a low permeability to gas so soaking in gas shouldn't effect them.
Old Jun 18, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
you do not have a lifetime warranty on the injectors. you have 30 days before ebay will not help you or let you file a dispute. you have 60 days until paypal will not help you get refunded. clock's ticking. get replacements from the seller right away and leave yourself time to file a dispute before you can't. so many people get burned by those ebay warranties it's insane. all the seller has to do is not respond to you after a month and you'll never get anything out of them.
did you check that the connectors are seated properly and ohm the injectors with a multimeter?
Old Jun 19, 2018
oneheadlight's Avatar
oneheadlight is an unknown quantity at this point
Hello all
I just recently replaced my fuel injectors on my D16Y8 with OEM reman injectors from eBay........
hey!! you posted this exact same post over at honda-tech. Ok I'll post my response here as well...
I'm not surprised REMAN injectors are a joke! They cannot rebuild the internal seals! I went through this recently on my civic.The original injectors went bad, replaced them with re-manufactured injectors, one of the WORST ideas ever. I ended up with lack of power, then mpg's, eventually the car was bogging down. I read the live data on my OBD2 scanner, the fuel trims were running extremely rich! That was it, time to buy new!
I bought the Standard Motor Products (SMP) brand of NEW injectors, turns out they're made in USA! I think it's the south carolina manufacturing plant. Got them from summitracing.com (about $80 each) and it was drop shipped directly from SMP. I haven't had another issue at all! I would suggest you get new injectors then thank me when you see how much better your engine performs!
So again.. people listen!! Do NOT buy reman injectors, only buy NEW, unless you like to have problems.
iceminion
Buy, Sell, & Trade - Archive
Jun 3, 2009 05:15 PM
mishkakasalapiy
Oct 20, 2005 03:56 AM
gearbox
22
Jun 1, 2005 07:47 AM
ricergribbs
Apr 26, 2004 05:01 PM
Purple2001Civic
Oct 24, 2002 03:10 AM
