Where does air go from filter?
Old Jun 8, 2018
prr's Avatar
prr
prr is an unknown quantity at this point
I have occasionally heard that sand can enter the engine in gaps in the path after the air filter. I took a peak under the hood this morning, expecting to see hoses leading from the air filter, but didn't see anything to check. It looked like pretty solid metal that the filter was connected to.
Sorry if this is a dumb question--not a mechanic here, just trying to keep my 98 Civic (just rolled over 200K this week) going as long as it possibly can.
So what do I check, if anything?
Old Jun 8, 2018
Colin42's Avatar
Re: Where does air go from filter?
does it still have the factory air box?
the bottom of the air box is clamped to the throttle body with a hose clamp, there's a rubber gasket in between. as long as the clamp is tight and the gasket is in good condition it should be fine
Old Jun 8, 2018
Not if the stock breather is assembled and installed correctly.
Old Jun 8, 2018
prr's Avatar
prr
I did look again. I'm not 100% sure where the gasket is--or if it is visible without anything being moved--but I touched and poked around below the air filter, and nothing was moving or looked loose, so I suppose that is a good thing.
Old Jun 8, 2018
prr's Avatar
prr
Yes everything there is factory (except the air filter itself, of course lol)
118mph
Sep 29, 2010 01:26 AM
redvtec04
Apr 25, 2004 09:36 PM
playaz0429
15
Apr 10, 2004 08:10 PM
spencerkam
Feb 22, 2004 07:38 PM
SoNiCcIvIc
15
Nov 23, 2002 10:42 AM
