99 civic keeps shutting off while driving
Old Dec 9, 2017
Brenda Morales's Avatar
Brenda Morales is an unknown quantity at this point
Usually when it shuts off the RPM goes down to 0 while im driving and the battery and oil light comes on right as its shutting off. Once I manage to pull in somewhere I need to let the car sit for 10ish minutes before it lets me start it again, anything less than that it will just crank and not turn on. Sometimes i can go 4 days or even a week without it turning off at all and then having the same problem again and having it shut off after 10-15 min of driving. Also no codes come up and the mechanic I went to said it could be the distributor or ignition coil, not sure exactly what it was called but he said he wasnt sure because he wasnt getting a code come up for it. Hope someone can help. Thanks!
Old Dec 9, 2017
Wankenstein's Avatar
Re: 99 civic keeps shutting off while driving
Possibly ignition coil. Check spark per Ezone method: long screw driver to ground and slowly increase air-gap to see arc length/spark quality. Testing it in this manner could finish off the coil if it's weak. In this case finishing off a weak coil is a good thing as it needs to be replaced with a new one and the most likely cause of your posted issue.
Another possibility may be a failing/weak/intermittent fuel pump. Consider replacing the fuel filter if last replacement/mileage is unkown.
Old Dec 9, 2017
Vague....
Doubt coil because they always seem to be one fail and done, no comeback
Igniter might act that way with random fails that get worse and worse until final death,
Main relay could act that way
Ignition switch fail would usually leave the lights on the dash dark just like the key was shut off ,,,,and the bad contacts make the warning lights flicker as you slowly roll the key
Old Dec 9, 2017
Originally Posted by ezone
Vague....
This is why I hesitated becoming a moderator. As a moderator I feel I should be more accurate with my responses. As a regular member I felt I could guesstimate..lol.
Old Dec 9, 2017
That's not what moderating is about.....
I'm a troubleshooter and technician first..........technical details and accuracy are everything in my daily work....and it kinda carries over to this
Old Dec 9, 2017
This site is pretty tame compared to some other ones. I haven't permormed any "mods" to date..LOl
Thankfully so.
kittykate83
Jun 21, 2019 12:24 PM
Supa Jay
Apr 8, 2010 10:50 AM
booba5185
15
Jul 5, 2007 04:47 PM
fourkilos
Mar 27, 2002 11:16 PM
